Hi! I�m new to this forum and a newbie translator. I have downloaded a couple of .mkv films which work very fine to watch on my new tv via my external hard drive. When I watch the films this way, however, the subtitles aren�t visible, but when I watch them on my pc via Media Player Classic the subtitles work fine! (Unfortunately I can�t play the films via my pc due to the fact that it misses the facility of an HDMI interface).
This is the case in about 9 out of 10 films. However, I got really surprised when I watched Green Zone, also a .mkv film, because there the subs work fine. What may be the problem?
I have used mkvmerge GUI and carried out 10 merges with different settings with nothing as a result. Does anyone have an idea what may be the problem?
Curious as a cat with 9 lives left
Kjell
Many TVs and other media players cannot play embedded subs. You have to extract them as separate files with the same base name. For example:
My Movie.MKV
My Movie.SRT
There may also be limitations on the type of subtitle files the TV/player supports embedded, or not. -
Thank you for your quick answer. I'll go to the tv manual and look, maybe that mention something about this.
If I chose to extract a sub file from a film and name it properly as you suggest, is it then enough if I put it in the same mapp as the .mkv video file?
Kjell -
Hello again, jagabo and everybody else!
Due to a lot of trial and error on my behalf, I've been away from the forum for a while. I did as you, jagabo, suggested and put the srt file outside the mkv file, but inside the folder, and gave it the same name (exept .mkv of course). That didn't work either.
So, in mkvmerge GUI.exe, I tried to remove the three sub files, eng, spa and fre, that were there in the first place, just in case they would confuse the reader in my tv and miss the srt file in the folder. That didnt work, because mkvmergeGUI suddenly decided to go not willing on me and lock it self. So I reinstalled it with zip zero result and realised I had to remove the mkvtoonix for good.
Does anyone know of any similar software to mkvtoolnixGUI?
In addition to this I have also, according to an advice from a neighbour forum, changed the attached .srt-file in question from the original UTF-8 format to ANSI format and put in the same folder as the .mkv file, but that doesn't help either.
Just for your info I have a Samsung 40" Full HD, 3D ready. I'm going to the Samsung site to see if there's any information there...
I will be greatful for any suggestions of any kind in this matter...
Best Regards/Kjell of Sweden
MPC-HC displays two lots of subs overlapping?
By snadge in forum Software PlayingReplies: 3Last Post: 23rd Jul 2011, 13:00 -
DVDlab Pro: Text set as visible isn´t visible in the result
By Alex89 in forum Authoring (DVD)Replies: 14Last Post: 12th Aug 2010, 08:09 -
MPC and SRT subs
By marioval in forum Software PlayingReplies: 11Last Post: 1st Jan 2008, 18:45 -
Subs play in MPC but not on disc
By pzoggy7 in forum SubtitleReplies: 3Last Post: 13th Nov 2007, 11:03 -
Video not visible in editing software/visible in Media Player
By kb1985 in forum Newbie / General discussionsReplies: 1Last Post: 1st Aug 2007, 19:21
