I had several Video TS files from a movie. I could only play the movie on my computer. Later I used iSkysoft to convert all of those files into a format,so I could burn the movie on a DVD,and be able to watch the movie on a regular DVD Player.
I made the conversion with iSkysoft,and end up with 16 VTS file and one Video TS files.
I would like to know which would be the best software to burn these files on a regular DVD,and watch the movie.
Your assistance to my request,would be greatly appreciated!
Take Care![]()
Burn the VIDEO_TS folder with imgburn. See http://forum.imgburn.com/index.php?showtopic=4632
You can also join dvds/video_ts folders with the free dvdshrink in the reauthoring mode. -
Thank you for your prompt response. As I mentioned before after the conversion of the files with iSkysoft, I have 16 VTS files,and one Video_TS file of only 73 KB.
I have used DVD Shrink with these files from a DVD movie of 7GB,and burn it with imageburn,but I could not play it on a regular DVD player, only on my computer, meaning no autoplay when inserted on the DVD player.
I still have the DVD that I converted with DVD Shrink,and burn with imageburn (This one has one Audio_TS empty file,and one Video_TS folder with several VTS files,and a PgcEdit_backup file),those are te files I used with iSkysoft Video converter. I have damaged a couple of DVDs, I just want to make sure,before making another burn.
Thanks! -
Check this tutorial. It will help you to create DVD compliant folder ready to burn with ImgBurn
http://www.dvdshrink.info/reauthor_basic.php
Trying to edit a movie on windows movie maker (Canon Vixia HF R20)
By Classic in forum EditingReplies: 1Last Post: 8th Mar 2012, 12:07 -
HDTV makes DVD movie look "less" like a movie?
By breakchange in forum DVB / IPTVReplies: 73Last Post: 6th Oct 2011, 09:28 -
Whats the diffrence between AC3 Blu-ray movie and a x264 movie?
By evdeneale in forum Newbie / General discussionsReplies: 1Last Post: 20th May 2011, 23:16 -
How can I convert a widescreen movie to full screen movie on PSP?
By VidHunter in forum MacReplies: 2Last Post: 9th Nov 2008, 22:20 -
Resident Evil First movie ...Not Apocalypse the 2nd movie backup issue!!!
By vanc in forum DVD RippingReplies: 0Last Post: 19th Oct 2007, 11:33
