Hi, sorry for this silly question. I searched hard for an answer with no luck.
I have the Lacie Rugged Cinema - which i love. I download movies, transfer onto the device, and then connect with HDMI to my TV.
I noticed awhile ago that if the USB cable is still in the device then you cannot also connect the HDMI cable. In other words, for some reason, you need to only have one cable plugged in at any time.
In any event, all of sudden, i cannot power the device on WITHOUT the device being plugged via USB to the computer.
In other words, the device works perfectly well when connected to the computer with USB.
But when i remove the USB cable and then try to power the device on using the remote -- the blue light does not come on.
I only see two possible reasons but there must be a third:
1) The power supply device is broken
2) The remote is broken
3) What else?
Number 1 is not true. Because when connected successfully via USB to the computer, it also requires the power supply.
Number 2 could be the reason. But i believe that the device is supposed to start to hum when plugged into the power supply and it is not doing so now.
ANY IDEAS? thanks in advance
Please don't cross post. I removed your other thread.
And nope, I have no ideas...
looking for usb power only cable
By aedipuss in forum ComputerReplies: 8Last Post: 23rd Nov 2011, 13:49 -
What is this device? (rf in-out with power supply?)
By cynikalhedonist in forum Capturing and VCRReplies: 11Last Post: 23rd Mar 2011, 12:11 -
Building a Low Power Desktop...with Laptop like power?
By Moontrash in forum ComputerReplies: 31Last Post: 18th May 2010, 23:15 -
Slightly OT -- Power Supply for External USB HDD used with Portable Device
By GrayStrickland in forum Portable VideoReplies: 2Last Post: 25th Mar 2009, 15:50 -
tv/remote is locked!!!??? only power button works!?
By ted demen in forum DVD & Blu-ray PlayersReplies: 1Last Post: 31st May 2007, 22:44
