I'm getting movie file that are of high quality high res and large size files but I want to convert them to something that won't take up a lot of space but kinda keep the quality of the movie. With a file size range of 1-1.5 Gig and if need be 2 Gig but only on the movies that really.
Here is the media info on one of the files
What part of the profile of x256 do I need to edit or if I need to convert to a new codec no problem it'll just take longer I think.Code:General Unique ID : 175402680536199287503279639488007528482 (0x83F553D5892059F3A6BABA905DB86022) Complete name :dp-aao.x264.mkv Format : Matroska Format version : Version 2 File size : 4.37 GiB Duration : 1h 30mn Overall bit rate : 6 915 Kbps Encoded date : UTC 2009-11-09 22:00:27 Writing application : mkvmerge v2.9.7 ('Tenderness') built on Jul 1 2009 18:43:35 Writing library : libebml v0.7.7 + libmatroska v0.8.1 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 5 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1h 30mn Bit rate : 6 467 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.293 Stream size : 4.00 GiB (92%) Writing library : x264 core 68 r1183M f21daff Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=8 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=12 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=6467 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00 Language : English Default : Yes Forced : No Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : A_AC3 Duration : 1h 30mn Bit rate mode : Constant Bit rate : 448 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 290 MiB (6%) Language : English Default : Yes Forced : No
And most of them look like this but again I just need to reduce the file size
Thank in advance
Just read that I can use the same codec and lower the bit quality the file size will reduce
but what will get the file size down to 1.3Gb.
Also is there a program that will give you and file size quote before the file conversion the one I have does it but its very vague -
Use a bit rate calculator, like this one: https://www.videohelp.com/tools/VideoHelp-Bitrate-calculator Go to advanced mode and plug in your desired size and the running time and it will give you the bitrate. Works the same with any codec, including H.264. There are other bitrate calculators in our 'Tools' sections and some codecs have them as part of the settings. You should be able to just pass through the AC-3 audio as it's probably already compacted enough.
Of course you will take quite a hit on video quality, but try it and see how it looks. -
Just by going from 1080P to 720P you have loss quite a bit of quality. Reducing file size further will cause addition quality loss. You can however mitigate the quality loss to a point, by making the video more compressible. I would recommend ripbot to further compress the movies, it uses avisyth to process the moves. You can add additional filters to the generated script to sharpen the image a bit then do light to medium noise removal, this will increase compressibility allowing smaller file size with out sacrificing as much quality.
Murphy's law taught me everything I know.
Witch the best way to convert a BluRay Movie to MKV ( size DVD9 or else)
By siopilos in forum Blu-ray RippingReplies: 9Last Post: 12th Feb 2012, 21:59 -
converting movie to HD but low space format
By shahzadashraf30 in forum Video ConversionReplies: 7Last Post: 23rd Aug 2011, 06:32 -
converting down to low size yet maintain good quality
By lawlbear in forum Video ConversionReplies: 3Last Post: 19th Dec 2008, 19:06 -
convertxtodvd converting files -if the target size exceeds one GB
By sumeshkri in forum Video ConversionReplies: 2Last Post: 3rd Nov 2008, 22:51 -
Low size, high quality WMV files
By devilfruit in forum Video ConversionReplies: 2Last Post: 29th Jan 2008, 18:08
