I have AVCHD home videos that wouldn't play from my Hard drive on the blu ray via the USB port, so I used tsmuxer to put the video files into .ts. The AVCHD extension was m2ts, and after the Muxing, it was MPEG-2 ts video with .ts extension.
The video files NOW play on my blu ray but they occasionally have 1 second pauses, every 10-15 seconds. This is really irritating. Is there some setting on the tsmuxer software to eliminate this, so that the video plays smoother?
James
Maybe it is the HARD drive. Because I just put a couple of the video files that were pausing when I went from the Hard drive to the blu ray via the USB port, onto a Flash USB stick and the same video played with NO pauses. Is there something that I need to do to the Hard drive? Or maybe the cord is too long that goes from the Hard drive to the Blu Ray player and the data can't travel fast enough? I don't know. What do you all think?
JamesLast edited by jbitakis; 13th Nov 2011 at 21:20.
Well its not the Cord from the Hard drive because I found a shorter cord and it is still pausing when I use the Hard Drive.
tsMuxer BluRay audio out of sync
By gareth41 in forum Authoring (Blu-ray)Replies: 1Last Post: 14th Oct 2011, 01:47 -
Video Pixelation Converting MKV To AVCHD Using TSMUXER
By uscstyle in forum Video ConversionReplies: 26Last Post: 1st Apr 2011, 19:29 -
Tsmuxer AVCHD problem?
By mufasa2 in forum Video ConversionReplies: 4Last Post: 22nd Aug 2010, 04:19 -
Using tsmuxer to convert mkv to bluray and the aspect is squished.
By heckybaby in forum Authoring (Blu-ray)Replies: 8Last Post: 9th Jun 2010, 08:07 -
Wrong resolution/framerate on mkv converted to bluray with TsMuxer
By tomamitai in forum Video ConversionReplies: 2Last Post: 30th Mar 2009, 03:13
