  1. Member wulf109's Avatar
    Jul 2002
    Anyone know what the Write Chapter button does?
  2. Member dragonkeeper's Avatar
    Jul 2003
    No. But a better question is why are you still using evodemux?
    Murphy's law taught me everything I know.
  3. Member wulf109's Avatar
    Jul 2002
    Converting the last of my HD-DVD's to BR.
  4. Member dragonkeeper's Avatar
    Jul 2003
    Oh. Use Ripbot to demux and convert assets.
  5. Member wulf109's Avatar
    Jul 2002
    TSmuxer works fine without encodeing. I use Evodemux to get the correct chapter stops. TSmuxer takes 15 minutes,Ripbot would take 5 hours.
  6. Member dragonkeeper's Avatar
    Jul 2003
    I wasn't suggesting to re-encode, but rather to re-purpose the project files. If you build the project in x264 all the streaams are demuxed and placed in a temp folder you can then use these assets in tsmuxer to mux a finished product. I only suggest this because Evodemux had problems with several HD-DVD, and I didn't find them till actually playback.
  7. Member wulf109's Avatar
    Jul 2002
    Ripbot creates a chapter file that TSmuxer doesn't recognize. I used Makemkv to create an mkv file which TSmuxer does recognize including the chapter stops.
  8. Member dragonkeeper's Avatar
    Jul 2003
    Understood, just an FYI in case you run into a problem using evodemux on some HD-DVD titles, Ripbot saved when i was converting my HD-DVD movies.
