  1. i have 2 h.264 mp4 files that i want to join into a single file, and i tried using avidemux to do this, but i'm not very experienced with the program and i'm getting errors. here is the metadata of both files:
    file 1:
    General
    Complete name                    : D:\Temp\a1.mp4
    Format                           : MPEG-4
    Format_Commercial_IfAny          : XDCAM EX 25
    Format profile                   : Base Media
    Codec ID                         : isom
    File size                        : 3.90 GiB
    Duration                         : 2h 6mn
    Overall bit rate mode            : Variable
    Overall bit rate                 : 4 417 Kbps
    Encoded date                     : UTC 2011-09-07 16:59:34
    Tagged date                      : UTC 2011-09-07 16:59:34
    Cover                            : Yes
    Video
    Format                           : AVC
    Format/Info                      : Advanced Video Codec
    Format profile                   : High@L4.0
    Format settings, CABAC           : Yes
    Format settings, ReFrames        : 3 frames
    Codec ID                         : avc1
    Codec ID/Info                    : Advanced Video Coding
    Duration                         : 2h 6mn
    Bit rate mode                    : Variable
    Bit rate                         : 4 096 Kbps
    Maximum bit rate                 : 25.0 Mbps
    Width                            : 1 920 pixels
    Height                           : 1 080 pixels
    Display aspect ratio             : 16:9
    Frame rate mode                  : Constant
    Frame rate                       : 23.976 fps
    Color space                      : YUV
    Chroma subsampling               : 4:2:0
    Bit depth                        : 8 bits
    Scan type                        : Progressive
    Bits/(Pixel*Frame)               : 0.082
    Stream size                      : 3.61 GiB (93%)
    Title                            : Alexander Revisited part 1
    Writing library                  : x264 core 114 r1924 08d04a4
    Encoding settings                : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4096 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=25000 / vbv_bufsize=25000 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00
    Tagged date                      : UTC 2011-09-07 17:03:20
    Audio
    Format                           : AAC
    Format/Info                      : Advanced Audio Codec
    Format profile                   : LC
    Codec ID                         : 40
    Duration                         : 2h 6mn
    Bit rate                         : 317 Kbps
    Maximum bit rate                 : 335 Kbps
    Channel(s)                       : 6 channels
    Channel positions                : Front: L C R, Side: L R, LFE
    Sampling rate                    : 48.0 KHz
    Compression mode                 : Lossy
    Stream size                      : 287 MiB (7%)
    Title                            : Ä
    Language                         : English
    Encoded date                     : UTC 2011-09-07 17:02:40
    file 2:
    General
    Complete name                    : D:\Temp\a2.mp4
    Format                           : MPEG-4
    Codec ID                         : isom
    File size                        : 2.69 GiB
    Duration                         : 1h 27mn
    Overall bit rate                 : 4 414 Kbps
    Encoded date                     : UTC 2011-09-08 02:04:46
    Tagged date                      : UTC 2011-09-08 02:04:46
    Cover                            : Yes
    Video
    Format                           : AVC
    Codec ID                         : avc1
    Duration                         : 1h 27mn
    Color space                      : YUV
    Bit depth                        : 8 bits
    Stream size                      : 2.49 GiB (93%)
    Title                            : Alexander Revisited part 2
    Tagged date                      : UTC 2011-09-08 02:05:57
    Audio
    Format                           : AAC
    Format profile                   : LC
    Codec ID                         : 40
    Duration                         : 1h 27mn
    Bit rate                         : 317 Kbps
    Maximum bit rate                 : 334 Kbps
    Stream size                      : 198 MiB (7%)
    Title                            : Ä
    Language                         : English
    Encoded date                     : UTC 2011-09-08 02:05:26
    when i open these in avidemux i get a prompt that asks me to convert or not convert which could result in frame accuracy problems. if i choose no, it continues to load the files but then crashes. so i choose to convert when i open the files. i chose append to add the second file after the first. i have my format option set to MP4 and audio/video set to copy. when i save the file, then open it, i notice that the audio and video are not synced properly.
    does anyone know what i'm doing wrong ?
  2. Try a nightly build (2.6 beta build) , they work better with h.264 than the 2.5.x branch
    http://avidemux.razorbyte.com.au/
    or
    http://avidemux.org/nightly/win32/
    alternatively you can try appending in mp4box (yamb) or mkvtoolnix (re-wrap into mkv)
  3. Originally Posted by poisondeathray View Post
    or
    thanks for the suggestion, i tried yamb and it didn't want to output correctly, it kept crashing. i'll try a beta build of avidemux, but should i be using a 64 bit or 32 bit build ?
  4. i just tried the 64 bit 2.6 beta avidemux and it worked perfect, no artifacts or problems with the output. thank you
  5. been a while since this thread, there are updated builds of Avidemux 2.6 for windows, has anyone experienced any issues with the latest build (7800) ?
    i am using 2.6 because it works well with combining MP4 movies that i make with ripbot using h264 and aac audio.
    the build i'm on now is 7652, 2.6.0 ...
  6. Member Ethlred's Avatar
    Feb 2008
    I don't get why 2.6 is a beta vs 2.5 is the stable version. 2.5 is NOT stable in comparison to 2.6.
    Mar 2011
    Nova Scotia, Canada
    I've experienced that with previous versions ... just downloaded the newest build of 2.6. I'll try it later today.
