I have a video of the Eiffel Tower of 2:55 minutes which I took from my Sony WX7 Cybershot sideways . It's an .mp4 file & has B-frames in it as well .The codec is H264 . Now , in this video from about 1:28 to 2:05 , I have made the camera straight . To rectify my mistake here's what I did . First , I rotated the whole file using Avedimux by 90 degrees & saved the output to a new file . The Video became straight except for the portion from 1:28 to 2:05 which now slants to the right by 90 degrees . In order to rectify this , I tried to rotate this particular portion ( 1:28 to 2:05) in the new file (Modified Video) by 270 degrees & save to another new file , so that I can have the whole Video straight . However , while trying to do this , Avedimux crashes . I tried 3 times , but all 3 times it crashed at around 70 % .
Any Ideas ?
This is the answer that I got from "Avedimux Forum" :
you cant rotate just a part of the video
else it will go from
1280x720 to 720x1280 right in the middle
What you can do is extract the 2nd part, rotate + add black border/crop so that you end up with 1280x720 or whatever .
Well , I've tried this (I made both the Videos 1280 x 1280 & then joined them together . However , the resulting Video becomes a little smaller from all sides . So , either I don't know how to add the Borders correctly or in case if the Video is actually getting smaller after adding the Black Borders , then maybe I'll have to remain content with my Original Edited Video ( The one in which I've been able to get at least most of the Video straight) .
Is there anything else that could be done ? What exactly is the right way to add Borders to a Video (Without making the Video Image smaller in size) ?
Results 1 to 1 of 1
[help] MKV with video codec H264 to mp4
By ageega in forum Video ConversionReplies: 2Last Post: 17th Sep 2010, 00:46 -
I'm looking for a good MP4-2/H264 video encoder which should NOT be based o
By clipperyoungamerica in forum Video ConversionReplies: 7Last Post: 19th Mar 2010, 16:54 -
Flash with high quality video (MP4 with H264 video and AAC audio)
By Baldrick in forum User guidesReplies: 49Last Post: 19th Mar 2010, 09:05 -
best tool from video/audio TS to mp4 h264
By nodollas in forum Video ConversionReplies: 1Last Post: 31st Jan 2010, 06:55 -
Do you prefer mp4 or mkv for h264 video?
By yoda313 in forum PollsReplies: 18Last Post: 18th May 2009, 13:56
