    Oct 2009
    This is a free stream. Is there a tool that I can use to record this? I would like to save this as an mp4 file, if possible.
    http://ulive.cbssports.com/?media=258597
    Thanks,
    TC
    My Dell PC system info.....3.4 Ghz Quad Core i7 processor....... 12 gigs of ram DDR3...... Windows 7 ultimate 64 bit.......video card Nvidia GTX 650
  2. Member bat999's Avatar
    Feb 2008
    Hi
    The RTMPDump command is here --> http://pastebin.com/nqXCi5sX
    It's saved as an flv file, but will easily re-pack as mp4 using a FFmpeg command like this:-
     ffmpeg -i bradleynterview.flv -vcodec copy -acodec copy bradleynterview.mp4
    RTMPDump is here -- http://rtmpdump.mplayerhq.hu/download/rtmpdump-20110925-git-6230845-win32.zip
    Latest "Static" build FFmpeg is here --> http://ffmpeg.zeranoe.com/builds/
    Last edited by bat999; 11th Nov 2011 at 21:52. Reason: Added sources for RTMPDump and FFmpeg.
  3. It looks like RtmpExplorer will work too.
    Oct 2009
    Thanks for the responses.
    What is the difference between RTMP dump and RTMP explorer?
    Is RTMP explorer basically RTMP dump plus a GUI?
    TC
