    Aug 2008
    Greece
    Hi i want to split one 10gb mkv movie with dts, ac3 and srt subtitles into a lot of single layer dvd discs.
    How i can do that with tsmuxer 1.10.6?
    I choose to split the movie into 4400gb files but how i write it then so it can fit into a single layer dvd disc that in stream folder has all the files.
    I want to put these single layer dvd into a playstation 3 and play it with greek subtitles...
    Split to several m2tss first and the use tsmuxer again and output each m2ts to an avchd disc/bdmv folder.
    Or try multiavchd, bdtoavchd or avchdcoder.
    And this is not any camcorder avchd issue. Moving you to blu-ray/avhc authoring section.
    Aug 2008
    Greece
    If i choose from tsmuxer the mkv and srt file and choose the split options that tsmuxer has here:
    Then how i must write each dvd?
    And i do the split m2ts files with srt greek subtitle inside BUT i can't see the greek subtitle to any program even with total media theatre 5.
    So what do you suggest?
