Hey Guys, first post here..hope you can help me out.
Ive got a couple of Quictkime videos with the PNG codec (and a alpha channel). This file plays fine in Quicktime itself...
However, Im trying to play these on my player, which is potplayer. THe video starts, but then stutters and hangs.. I know it can play fluently cause it did play fine before I formatted my PC yesterday... Ive disable the internal codecs of the player, but im not sure which splitter/video decoder to use to make it work properly. It's says when I look at the file playing info..that the codec it's using is FFmpeg decoder, and I think that there problem lies there.. But I can't seem to change it...
It does play Quicktime (H264) or Quicktime (Photo Jpeg fine btw)..
Here are my specs:
So it's basically a clean install..did it yesterday:
Windows 7, 64 bit and the only codecs ive installed so far is the K-lite codec pack 64-bit. (Potplayer is a 64 bit player I believe)
Well, hope I you guys can help me out! Thank you in advance!
Results 1 to 1 of 1
Quicktime Video Codec
By svaleri in forum Newbie / General discussionsReplies: 2Last Post: 21st Aug 2008, 20:44 -
What Quicktime codec would be best...
By patrean in forum Newbie / General discussionsReplies: 6Last Post: 23rd Jan 2008, 11:40 -
RV24 Codec for Quicktime?
By ericfoust in forum EditingReplies: 0Last Post: 5th Dec 2007, 23:20 -
Qcelp codec only in Quicktime
By mrcoolekin in forum Video ConversionReplies: 0Last Post: 1st Aug 2007, 18:00 -
quicktime codec question
By Shaorin in forum Newbie / General discussionsReplies: 1Last Post: 24th May 2007, 05:29
