Page 6 of 27
FirstFirst ... 4 5 6 7 8 16 ... LastLast
Results 151 to 180 of 809
  1. MkvToMp4 author oreons's Avatar
    Nov 2011
    Russia
    Closet_Geek,
    Without the movie sample is difficult to determine the cause. Try renaming the file only Latin letters and put it in a directory with a simple name. For example c:\movie\film.mkv
  2. 1st the most impressive tool so far, great work.
    2nd what im i doing wrong and the subtitles don't appear into my movie at xbox360?
    Im using both .m4v and .mp4 extensions but no chance... only at my computer if i enable the subs throu mpc they appear...
    Any help to my problem?
  3. Hi oreons,
    Your program is fast and works great for my older computer. I have been having problems converting mkv to mp4 though. If you need I can you PM your the media info the Mkv I'm am trying to convert.
    The main error I'm getting is "Audio 1 error Does not match time source (01:32:33.590) and result(00:27:06:00)
    Do you know of a possible fix for this.
    I also get "Build file error" That could be from low disk space though.
    Thanks in advance.
  4. i want to install the new version, but how do i uninstall previous version? there's no listing for it in my control panel's installed apps
  5. MkvToMp4 author oreons's Avatar
    Nov 2011
    Russia
    gotten14,
    Subtitles are for Apple devices.
    thrashman,
    Free space should be 4-x greater than the original file.
    J81CHAT,
    MkvToMp4 - portable program. Erase the old distribution and use a new
  6. @oreons
    So no subs for xbox360? Are you thinking to implent this in the future?
  7. MkvToMp4 author oreons's Avatar
    Nov 2011
    Russia
    gotten14,
    If you make video with subtitles in the program Yamb, then subtitles are visible on the xbox360? I have no xbox to test ...
  8. Originally Posted by oreons View Post
    gotten14,
    I found some guides but the procedure is too complicate compare to your awesome program.
    If you can make such a thing as displaying to xbox360 it would be the best solution to xbox360 and ps3.
    As we say an All in one video suite(Xbox360, PS3, Apple... Think about it
  9. I was wondering if anyone can tell me how to embed the subtitles without actually trans-coding/converting the video, making the words appear without having to press any button on the player? Basically, I want to know what format the subtitle has to be in that embeds it into the video stream?
  10. MkvToMp4 author oreons's Avatar
    Nov 2011
    Russia
    gotten14,
    Can you check that the subtitles works on xbox after repackaging by Yamb? If they work, I'll add support.
    chadwilliams,
    Hardsubs demand video transcoding.
  11. i love this app, i just wish i could pick a specific bitrate for audio, like 64, 96, 128, 160, etc.? Other than that, this app is perfect!
  12. MkvToMp4 author oreons's Avatar
    Nov 2011
    Russia
    J81CHAT,
    For QuickTime codec constant bitrate can be selected for music, for movies mode is TVBR (AAC True VBR mode)
  13. I think there was a tool that had working subtitles for XBOX 360. It was called GotSent. I think you could choose between softsubs and hardcoded subs, but I am not sure. Maybe you can look at it...
  14. Originally Posted by oreons View Post
    J81CHAT,
    -i see...hmmm, never heard of tvbr. Which audio codec do u suggest for best compatibility with most devices (itunes, xbox360, ps3, etc.)
    -m4v or mp4? mp4 is more compatible, right?
  15. I'm enjoying this tool. Thank you for the software. I'm curious if the input mkv has header removal compression do I have to put it through mkvmergeGui to fix it or does this app adjust auto-magically? Also if you accept feature requests I'd love to see it mux/demux mp4/m4v so if I have suitable video and audio tracks I can just mesh 'em.
    http://milesaheadsoftware.org/
    Fully enabled freeware for Windows PCs.
  16. MkvToMp4 author oreons's Avatar
    Nov 2011
    Russia
    J81CHAT,
    For Apple devices recommended m4v, as it possible correct switch audio tracks and subtitles.
    MilesAhead,
    Did not work with these files, I can assume that when unpacking it is corrected automatically.
    Maybe in the future it will be possible to add a video track as a separate file. Now you can add external audio tracks and subtitles alone or inside containers.
  17. Maybe in the future it will be possible to add a video track as a separate file. Now you can add external audio tracks and subtitles alone or inside containers.
    I played around with adding an audio track but I couldn't get rid of the one that was already there. For example, my set top box cannot play DTS(and does not have a downmix to stereo feature.) I could add AAC track, but I couldn't remove the DTS. If I removed the DTS first, then it wouldn't let me add the AAC. Kind of heads you win tails I lose situation.
  18. MkvToMp4 author oreons's Avatar
    Nov 2011
    Russia
    MilesAhead,
    You tried mkv or mp4? Mp4 need to enable edit mode (button) and then you can delete the track.
  19. Can anyone tell me how to increase the volume of the audio regarding the video stream using SOX? Basically, I am asking what configuration listed below is necessary for an augment/increase in audio sound?
    SOX:
    compand 0.0,1 6:-70,-43,-20 -6 -90 0.1 gain -n -0.1 treble +0.1
  20. I am trying to convert avi files created with Virtualdub to MP4 with MKVToMp4 v0.221a. The avi file is x264vfw for the video and PCM for the audio. The problem is that MKVToMp4 skips the audio conversion. The log.txt for eac3to shows "The format of the source file could not be detected. <ERROR>". Any idea what might be causing this error?
  21. Originally Posted by oreons View Post
    MilesAhead,
    Ok, so I have to do the conversion with multiple audio tracks. Then when I get mp4 output I can load it back in and delete and remux? I don't quite get it.
  22. MkvToMp4 author oreons's Avatar
    Nov 2011
    Russia
    Rebooter,
    Probably Eac3To does not understand Avi files.
    MilesAhead,
    To fully MP4 repackig:
    1. Load MP4 file to the program.
    2. Enable edit mode.
  23. Originally Posted by oreons View Post
    Rebooter,
    Any chance of fixing this in a future update? Maybe add a step to extract the audio for avi files to send to eac3to?
  24. MkvToMp4 author oreons's Avatar
    Nov 2011
    Russia
    Rebooter,
    You can extract the audio separately and load it into the program as an external track.
  25. Can anyone tell me how to increase the volume of the audio regarding the video stream using SOX? Basically, I am asking what configuration listed below is necessary for an augment/increase in audio sound?
    SOX:
  26. @chadwilliams: If it's dynamic range compression you want, look at the compand calls over at: http://forum.doom9.org/showthread.php?p=779165#post779165, I also posted a small collection of compand calls other uses over at https://forum.doom9.org/showthread.php?t=165807.
    also here's how compand works:
    sox %temp%\mono.wav %temp%\out.wav compand 0.3,5 6:-70,-60,-20 -10 -6 0.2 fade 1 2> nul
    REM                                            |   | |  |   |   |   |   | |   |      |
    REM                                            |   | |  |   |   |   |   | |   |      Ignore all error messages
    REM                                            |   | |  |   |   |   |   | |   Fade-in for first second
    REM                                            |   | |  |   |   |   |   | Initial sample time
    REM                                            |   | |  |   |   |   |   Expected initial level
    REM                                            |   | |  |   |   |   Overall output gain to avoid clipping
    REM                                            |   | |  |   |   Output range from zero to this number
    REM                                            |   | |  |   Input range from 0 to this number
    REM                                            |   | |  Ignore companding below this level
    REM                                            |   | Soft knee companding
    REM                                            |   Decay time is long to prevent rising noise in pauses
    REM                                            Attack time is fast to quiet loud music bumpers
    source: http://www.ericphelps.com/batch/samples/MP3_Recode.txt
    Other than that you can do the following:
    1st analyse your audio with sox: sox "path to audio" -n stat
    2nd check out the 'Volume adjustment' value presented in the output of 1.
    3rd boost volume with sox and 'gain X' where X is the value of 'Volume adjustment'
    this should boost the audio as much as possible without causing clipping
  27. Hi,
    The program is great.
    But one thing, all the tags it applied are not recognized by Zune for PC and Windows Phone.
    For example, it will not detect the video type as TV Series as well as the Series Title, Episode Number and Season Number are also not recognized by Zune. Is it possible to add this feature?
    Thanks!
  28. probably if someone knows which private atoms Zune uses to set those tags because it seeems they are not the normal atoms mp4 that are normally used for it. (see: https://zunetips.wordpress.com/2008/12/29/tagging-mp4-video-files/)
  29. [QUOTE=Selur;2184495]probably if someone knows which private atoms Zune uses to set those tags because it seeems they are not the normal atoms mp4 that are normally used for it. (see: https://zunetips.wordpress.com/2008/12/29/tagging-mp4-video-files/)[/QUOTE]
    Many files in Windows uses VersionInfo block to record such attributes. For example, .EXEs and .DLLs have Company Name etc. which you can see by viewing Properties of file in Windows Explorer. Zune uses same VersionInfo block for metadata of media files.
  30. MkvToMp4 author oreons's Avatar
    Nov 2011
    Russia
    abhijeet.pathak,
    To correctly display in Zune needs to be filled Xtra atom. At this time, library mp4v2 can not do it.
