Page 17 of 27
FirstFirst ... 7 15 16 17 18 19 ... LastLast
Results 481 to 510 of 809
  1. Please support batch transcoding to mkv, mkvtoolnix can do it, but it does not support batch transcoding
    Aug 2007
    I am having a problem with the tag-lookup. It keeps getting the episode names mixed up. It happens when I batch search, and when I individually search.
    EDIT: I found out why, iTunes is giving the application the wrong info. I unchecked load tags,info from iTunes, and it displays the correct episode info. So it seems the iTunes plugin is slightly broken (at least in my opinion/case)
  3. Can anyone tell me how to reduce the Format profile of High 10@4.1 to just High@4.1 because High 10@4.1 is not compatible with any of my devices, and won't play on my computer unless you mux the mp4 to mkv container. I hope Oreons can have a new repack parameter settings on the new mkvtomp4 update for the new Format Profiles
  4. really changing the profile&level of a H.264 stream requires reencoding
  5. Oreons,
    Is there any way to have MkvToMp4 watch a folder or get the program to work in an automated fashion?
  6. @Selur
    MkvtoMp4 and H264 Level Editor 1.4.0 allow you to change the profile level WITHOUT re-encoding. Nonetheless, I was only just concerned with the new Format Profile Settings: High 10, and if there was a way to change them.
    Apr 2013
    Colombia
    Is anyone having trouble with the search feature to find artwork and info about the movies?I am always getting a not found message for all the movies.
  8. @chadwilliams:
    You are wrong. They do only allow you to change the profile and level flags in the container!
    You can not change profile or level of a H.264 stream without reencoding and just changing the flags of a container does not change it's content. Changing the flags therefore only works properly (= content will be better playable with the new flags) if the content of the container was beforehand compatible with the new flags.
    Side note: both of these tools are 'dumb', they do not check the vbv&co values to check whether changing these values will create a real standard conform output.
  9. Hi, from today I have a problem during search tags on web. The sarch engine always say NOT FOUND with any title i try to search in movie DB. Some one can help? thanks a lot.
  10. Originally Posted by joys View Post
    I'm having exactly the same problem.
  11. Originally Posted by oreons View Post
    OK. Thanks. I'm downloading now.
  12. but... can i just use MkvToMp4.exe new file?
  13. MkvToMp4 author oreons's Avatar
    Nov 2011
    Russia
    joys,
    Archive includes new QT library
    Apr 2013
    Colombia
    Thanks, the search works fine now.
    Mar 2013
    Texas
    I knew if I was patient it would be fixed. Thanks oreons!
  16. Awesome! Search works again.
    Mar 2013
    Texas
    So I noticed that the 0.224Test2 adds a tag for the Writing Application? Intentional? I know I could do without it, or at least a way to choose to add the tag or not. The latter would be better, as I can see it being useful for testing. But I rarely use more than one version of an app to tag, or more than one app when tagging.
    Anyway, still an awesome app, thank you.
  18. MkvToMp4 author oreons's Avatar
    Nov 2011
    Russia
    dakon720,
    Enable tags on default depends on the checkbox in setup (Tags - Enable tags when loading file)
    Mar 2013
    Texas
    I'm speaking of a certain tag. These screens are of the same file, just different versions of the app.
    First with the newest version (MkvtoMp4 Test2).....
Name:	MkvtoMp4 Test2.PNG
    Now with the previous version (MkvtoMp4 Test1)...
Name:	MkvtoMp4 Test1.PNG
    The previous version doesn't add the tag for the Writing Application, is there a way to remove that, or turn it off? Not a huge deal, I just don't personally like it.
  20. @ Oreons,
    Weird question: Is this just another demo version? If so, can I just replace the MkvToMp4_0.223 mkvtomp4.exe file with MkvToMp4_0.224Test2's mkvtomp4.exe file or do I have to download the entire zip of MkvToMp4_0.224Test2 to get its maximum performance?
    Mar 2013
    Texas
    joys,
    From post #494 above
  22. Mr. Computer Geek dannyboy48888's Avatar
    May 2007
    Texas, USA
    Thanks for the fix, thought I was the only one
    and @chadwilliams hi-10 means it's a 10-bit AVC file so changing the flag will still not make it play as it is not decode-able by current (08-bit) players both stand alone or GPU based. Most software decoders can decode real time 1080p on a dual-core 2.5ghz or higher
    Last edited by dannyboy48888; 21st Sep 2013 at 23:38. Reason: answer 2 questions with one post
    if all else fails read the manual
  23. Hello Oreons and tanks for the update in the last day i can't found the movies info, but you save us tanks.
    I have a little request if it's possible.
    Could you add the store of Colombia or/and Mexico for get the info of the movies. the reason is for the movie titles and covers
    in spanish is diferent that in latin-america (almost time).
    for example:
    The movie Warm Bodies
    in Spain his name is: Memorias de un Zombie Adolescente
    and in Latinamerica is: Mi novio es un zombie
    Here is the links in apple stores of Spain, Colombia and Mexico
    Spain: https://itunes.apple.com/es/movie/memorias-zombie-adolescente/id670631198
    Colombia: https://itunes.apple.com/co/movie/mi-novio-es-zombie-warm-bodies/id649681872
    Mexico: https://itunes.apple.com/mx/movie/mi-novio-es-zombie-warm-bodies/id649681872
  24. MkvToMp4 author oreons's Avatar
    Nov 2011
    Russia
    dakon720,
    This tag is advertise the app, it will remain.
    augustosanchez,
    ok
  25. Hello, getting an error when converting the DTS MA audio i think or subtitles? I only get a video file and no audio when its done. Here is the log, any help appreciated
    Repack/encoder video to MP4 for Apple iPhone, iPad, ATV2. MkvToMp4 version 0.223
    Build from: Mar 15 2013 15:12:21
    Use log file: Temp\Logs\23_09_2013_10_33_06.txt
    QuickTime version: 6.5.2
    CoreAudioToolbox version: 7.9.7.9
    The file C:/Users/Murry/Plex Movies/movie.1080p.BluRay.mkv has an unknown subtitle format: PGS
    Added on list: C:/Users/Murry/Plex Movies/movie.1080p.BluRay.mkv
    Started processing file: C:/Users/Murry/Plex Movies/movie.1080p.BluRay.mkv
    Starting MkvExtract with the parameters:
    Tools\mkvextract\mkvextract tracks "C:/Users/Murry/Plex Movies/movie.UNRATED.1080p.BluRay.mkv" 0:"Temp\video.264"
    Extracting track 0 with the CodecID 'V_MPEG4/ISO/AVC' to the file 'Temp\video.264'. Container format: AVC/h.264 elementary stream
    Starting Eac3To with the parameters:
    Tools\eac3to\eac3to "C:\Users\Murry\Plex Movies\movie.1080p.BluRay.mkv" 2: "Temp\movie.1080p.BluRay_ac3_audio_0_EacID_2.a c3" -384 -progressnumbers -down6
    MKV, 1 video track, 1 audio track, 5 subtitle tracks, 2:03:04, 24p /1.001
    1: h264/AVC, English, 1080p24 /1.001 (16:9)
    2: DTS Master Audio, English, 7.1 channels, 24 bits, 48kHz
    (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48kHz)
    3: Subtitle (PGS), English
    4: Subtitle (PGS), English
    5: Subtitle (PGS), French
    6: Subtitle (PGS), Spanish
    7: Subtitle (PGS), Portuguese
    a02 The ArcSoft and Sonic decoders don't seem to work, will use libav instead.
    a02 The libav DTS decoder doesn't decode the full DTS-HD information.
    a02
    a02
    Eac3To terminated with error: 1
    Starting Mp4Box with the parameters:
    Tools\MP4Box\MP4Box.exe -new -delay 1=1 -add "Temp\video.264":fps=23.976:lang=eng:name="" -itags tool="MkvToMp4 [www.mkvtomp4.ru] version 0.223" "C:/Users/Murry/Plex Movies/movie.1080p.BluRay.m4v" -tmp "Temp/Mp4Box"
    AVC-H264 import - frame size 1920 x 1080 at 23.976 FPS
    AVC Import results: 178585 samples - Slices: 34536 I 224580 P 449004 B - 194298 SEI - 10652 IDR
    OpenGOP detected - adjusting file brand
    Setting up iTunes/iPod file...
    Saving C:/Users/Murry/Plex Movies/movie.1080p.BluRay.m4v: 0.500 secs Interleaving
    Correction mp4 file.
    TKHD atom correction for video. TRAK 1
    Writing tags in file: C:/Users/Murry/Plex Movies/movie.1080p.BluRay.m4v
    Open result file C:/Users/Murry/Plex Movies/movie.1080p.BluRay.m4v for test.
    The file <b>C:/Users/Murry/Plex Movies/movie.1080p.BluRay.mkv</b> is processed successfully
    File processing time: 1 h. 32 min. 38 sec.
    Total time: 1 h. 32 min. 38 sec.
    Already on the list: C:/Users/Murry/Plex Movies/movie.1080p.BluRay.mkv
  26. MkvToMp4 author oreons's Avatar
    Nov 2011
    Russia
    Version 0.224 - http://www.mediafire.com/?1a0oc04u539b5eg
    New in version:
    1. Added 64-bit version of the program. It runs the 64-bit versions of utilities from the Tools directory.
    2. The temporary directory can be changed in the settings.
    3. Added a flag to enable "Edit mode" for Mp4 files at loading.
    4. Working with the new SDK for themovidb.org
    5. If the program have not files for processing, the exit will be without questions.
    6. Ability to set audio delay, which will be default.
    7. Qaac encode CoreAudioToolbox now.
    8. Delay for the audio now set Eac3To. DelayCat no longer used.
    9. Update applications in the Tools folder.
    10. Added Colombia and Mexico iTunes stores.
  27. I'm a MEGA Super Moderator Baldrick's Avatar
    It should soon also be downloadable from www.videohelp.com/tools/MKVtoMp4
    Mediafire isn't that fast...2 hours to download the 135 MB file.
    edit: "Unknown network error." 2 more hours
  28. I'm a MEGA Super Moderator Baldrick's Avatar
    I can't download it. Any other mirror?
