Page 10 of 27
FirstFirst ... 8 9 10 11 12 20 ... LastLast
Results 271 to 300 of 809
  1. Converter m4v file does not have sound. I see the mkv has DTS 5.1 audio stream.
    Tried couple of suggestions on this thread but no luck
    Here is the log.
    Started processing file: X:/Downloads/King- 2008 - 1080P - DTS - Subs - Chapters - Sr33.mkv
    Starting Eac3To with the parameters:
    Tools\eac3to\eac3to "X:\Downloads\King- 2008 - 1080P - DTS - Subs - Chapters - Sr33.mkv" 2: "Temp\King- 2008 - 1080P - DTS - Subs - Chapters - Sr33_internal_audio_0_EacID_2.wav" -down2 -phaseShift -mixlfe -normalize -down16 -progressnumbers
    MKV, 1 video track, 1 audio track, 1 subtitle track, 3:01:34, 24p
    1: h264/AVC, 1920x816 24p (40:17)
    2: DTS, Telugu, 5.1 channels, 24 bits, 1510kbps, 48kHz
    3: Subtitle (SRT)
    v01 The video framerate is correct, but rather unusual.
    a02 The ArcSoft and Sonic decoders don't seem to work, will use libav instead.
    a02 Extracting audio track number 2...
    a02 Decoding with libav/ffmpeg...
    a02 Downmixing multi channel audio to stereo...
    a02 Reducing depth from 64 to 16 bits...
    a02 Writing WAV...
    a02 Creating file "Temp\King- 2008 - 1080P - DTS - Subs - Chapters - Sr33_internal_audio_0_EacID_2.pass1.wav"...
    a02
    Eac3To terminated with error: 1
    Starting MkvExtract with the parameters:
    Tools\mkvextract\mkvextract tracks "X:/Downloads/King- 2008 - 1080P - DTS - Subs - Chapters - Sr33.mkv" 1:"Temp\video.264" 3:"Temp\King- 2008 - 1080P - DTS - Subs - Chapters - Sr33_internal_sub_3.SRT"
    Extracting track 1 with the CodecID 'V_MPEG4/ISO/AVC' to the file 'Temp\video.264'. Container format: AVC/h.264 elementary stream
    Extracting track 3 with the CodecID 'S_TEXT/UTF8' to the file 'Temp\King- 2008 - 1080P - DTS - Subs - Chapters - Sr33_internal_sub_3.SRT'. Container format: SRT text subtitles
    Starting Mp4Box with the parameters:
    Tools\Mp4Box\Mp4Box -TTXT "X:/Downloads/MkvToMp4_0/Temp/King- 2008 - 1080P - DTS - Subs - Chapters - Sr33_internal_sub_3.SRT"
    Timed Text (SRT) import - text track 400 x 60, font Serif (size 18)
    Conversion done
    Tools\MP4Box\MP4Box.exe -new -delay 1=1 -add "Temp\video.264":fps=24.000:lang=eng:name="" -add "X:/Downloads/MkvToMp4_0/Temp/King- 2008 - 1080P - DTS - Subs - Chapters - Sr33_internal_sub_3_change.ttxt":lang=eng:name="" -itags tool="MkvToMp4 [www.mkvtomp4.ru] version 0.222" "X:/Downloads\King- 2008 - 1080P - DTS - Subs - Chapters - Sr33.m4v"
    AVC-H264 import - frame size 1920 x 816 at 24.000 FPS
    AVC Import results: 261261 samples - Slices: 6125 I 162326 P 92809 B - 265406 SEI - 4145 IDR
    Stream uses forward prediction - stream CTS offset: 7 frames
    Timed Text (GPAC TTXT) Import
    Setting up iTunes/iPod file...
    Saving X:/Downloads\King- 2008 - 1080P - DTS - Subs - Chapters - Sr33.m4v: 0.500 secs Interleaving
    Correction mp4 file.
    TKHD atom correction for video. TRAK 1
    TKHD atom correction for subtitle. TRAK 2
    Writing tags in file: X:/Downloads\King- 2008 - 1080P - DTS - Subs - Chapters - Sr33.m4v
  2. MkvToMp4 author oreons's Avatar
    Nov 2011
    Russia
    Eyedoctor2,
    Format : VC-1
    This format will be full converted. Need AVC (h264) for repacking.
    mfleigle,
    It doesnt require iTunes to be installed?
    iTunes does not need to search for artworks. You have a strange situation, I can assume that the iTunes search has been disabled in programm settings.
    ROBO731,
    Thanks, so the problem is that some of the lines are too long. Do you know how long is too long?
    I'm not sure how the maximum length, but very long lines you see at once in a text editor.
    eswarm,
    If Eac3To falls, you can try to extract the audio track in another program and convert to AAC. Then add a track to mkvtomp4 as external.
  3. Oreons, now i got audio but its out of sync with video. like couple secs faster than video
    Aug 2007
    Originally Posted by oreons View Post
    Eyedoctor2,
    Format : VC-1
    mfleigle,
    ROBO731,
    eswarm,
    I used the same exact mkvtomp4 folder/settings. Copied the complete folder from pc to laptop. Are you sure you are on iTunes 11 on your pc? I have even tried a fresh windows installation with iTunes 11, and a freshly unzipped mktomp4 (with default settings) no luck. Is there a log I can check for artwork search errors?
    EDIT: I decided to add mkvtomp4 to my firewall and now it works. But I never added it before, when it worked around the time of iTunes 10.
    Edit 2: Now I get the "Error: Track 1: NAL too big"
  5. MkvToMp4 author oreons's Avatar
    Nov 2011
    Russia
    eswarm,
    Audio #1
    Format : E-AC-3
    Delay relative to video : 17ms
    Audio #2
    Format : TrueHD
    Delay relative to video : 117ms
    Set the needed delay in the properties of the audio track manually.
    mfleigle,
    Program needs access to the Internet to search for tags and artworks.
    This is extract error, the file will not repacking. Need to use another source.
    Dec 2012
    The Netherlands
    Question: When I convert movies for the Apple TV 3 I get different subtitle sizes. The one is normal and the other is too small. How can I change it to the same size? What kind of subtitle format can I use?
    Aug 2007
    eswarm,
    Audio #1
    Format : E-AC-3
    Audio #2
    Format : TrueHD
    mfleigle,
    What program should I use?
  8. Hi,
    Thanks for this great program.
    Installed total media theatre but can not get Arcsoft decoder recognized by the program.
    Could anyone please give me some instructions to get it working? i have a 7 channels DTS file I wat to convert to AC3.
    Edited: Finally found a working Arcsoft codec, all is working fine now.
    Edited2: Have problems with DTS-ES 6.1 audio, it converts with arcsoft decoder but makes like metallic sounds, can't hear anything. Any idea? Thanks.
    Dec 2012
    Love the program. Works great for mkv but I have been having a problem recently with avi files. The video comes out very choppy when played on Apple TV 2. May just be a low quality originals as others have been fine. I tried Apple TV and Superfast presets with same result.
    Can you tell anything from this log? iTunes Video Dimension is 624x352. Thanks, Danny
    UPDATE: Just tried to see how the converted file played when playing through my BluRay USB port and it was fine so it appears to be with the Apple TV or maybe my network.
    Repack/encoder video to MP4 for Apple iPhone, iPad, ATV2. MkvToMp4 version 0.222
    Build from: Nov 13 2012 18:28:21
    Use log file: Temp\Logs\29_12_2012_15_29_59.txt
    QuickTime version: 7.7.3
    CoreAudioToolbox version: 7.9.8.2
    Added on list: E:/iTunes/Movies/3D/Sofia The First Once Upon a Princess [2012].avi
    Started processing file: E:/iTunes/Movies/3D/Sofia The First Once Upon a Princess [2012].avi
    Starting FFmpeg with the parameters:
    Tools\ffmpeg\ffmpeg -i "E:/iTunes/Movies/3D/Sofia The First Once Upon a Princess [2012].avi" -vcodec copy -an -y "Temp\video.mp4"
    Tools\ffmpeg\ffmpeg -i "E:/iTunes/Movies/3D/Sofia The First Once Upon a Princess [2012].avi" -map 0:1 -y "Temp\Sofia The First Once Upon a Princess [2012]_internal_audio_1.wav"
    Starting Qaac with the parameters:
    Tools\qaac\qaac --quality 2 --ignorelength --tvbr 95 "C:/Users/x/MkvToMp4_0.222/Temp/Sofia The First Once Upon a Princess [2012]_internal_audio_1.wav" -o "Temp\Sofia The First Once Upon a Princess [2012]_internal_audio_1.m4a"
    initializing QTML...done
    qaac 0.86, QuickTime 7.7.3
    MPEG-4 AAC Encoder 1.7.1, Variable Bit Rate q91, Best
    137533824/-1 samples processed in 01:57.218
    Overall bitrate: 182.709kbps
    Tools\MP4Box\MP4Box.exe -new -delay 1=1 -add "Temp\video.mp4":fps=29.970:lang=eng:name="" -add "C:/Users/dhamilton/MkvToMp4_0.222/Temp/Sofia The First Once Upon a Princess [2012]_internal_audio_1.m4a"#1:fps=29.970:lang=eng:name= "" -itags tool="MkvToMp4 [www.mkvtomp4.ru] version 0.222" "E:/iTunes/Movies/3D\Sofia The First Once Upon a Princess [2012].m4v"
    IsoMedia import - track ID 1 - Video (size 624 x 352)
    IsoMedia import - track ID 1 - Audio (SR 48000 - 2 channels)
    Saving E:/iTunes/Movies/3D\Sofia The First Once Upon a Princess [2012].m4v: 0.500 secs Interleaving
    TKHD atom correction for audio. TRAK 2
    Writing tags in file: E:/iTunes/Movies/3D\Sofia The First Once Upon a Princess [2012].m4v
    Open result file E:/iTunes/Movies/3D\Sofia The First Once Upon a Princess [2012].m4v for test.
    The file E:/iTunes/Movies/3D/Sofia The First Once Upon a Princess [2012].avi is processed successfully
    File processing time: 8 min. 49 sec.
    Total time: 8 min. 49 sec.
    Aug 2007
    Would it be possible to add the ability to convert the audio to mp3? I like to use the program to re-encode 5.1 ac3 avis to 2.0 AAC, but would rather be using mp3
  11. Click image for larger version
    Can i embedded .srt (subtitle file) to my video file ?
    i converted my .mkv file to .mp4 ,but i dont see my subtitle ?
    Is it posible to embedded .srt file to my .mp4 file ?
    i have ipad + iphone , also subtitle not showing
    also when i open .mp4 file with quicktime , subtitle not showing (in my .mkv file i have 2 subtitles files)
    thank you
  12. Great program... is there a way to increase the volume of the resulting MP4file? I'm finding the files are really low volume and I have to turn my receiver up almost all the way when I watch them on my PS3.
    Likewise, if I can easily increase the volume... can I redo my already existing MP4 files since I've already deleted my MKV files?
    Thanks!
  13. are there any command line options for MkvТоMp4?
    Jan 2013
    Brisbane, Australia
    I too would be interested in command line options - anything to make the process more automated. Any chance of open sourcing the code?
  15. I just discovered your tool a few days ago and it is awesome. Works great for getting files in order for Apple TV.
    Feature Request:
    I would love to see an ability to batch tag. I find myself doing a whole (tv) season at once and having to go to each file and searching the same thing with a different episode number. since it can detect the episode number from the title, it would be cool if once you searched for and found the right show, it could process all the different episodes at once.
    Thanks,
    Chris
    Edit Update: After playing around, i see that you can already do this by selecting all and then searching. This application rocks!
  16. hi oreons,
    i found a little bug. if i leave comment unchecked on audio track the programm crash.
    also was fantastic if MP4 optimization chackbox can be check by default.
    thanks. bye.
    Dec 2012
    The Netherlands
    Sorry but what does the preset 'Correct subtitles for QuickTime player' under the tab subtitles mean?
  18. Great utility and I thank you for your efforts!!
    I'm experiencing audio sync issues with a large number of TV show MKV files converted to M4V with MkvToMp4 v0.222. All the MKV files are H.264 @ 23.976fps with 5.1 AC3 audio. No re-encoding is being done on the video and I have AC3 set to passthrough. The resulting M4V files are slightly out of sync on my Apple TV 2 & 3. The original MKV files are perfectly in sync. I've had them for a while and watch them on many different hardware/software configurations. Any suggestions??
    Thanks again,
    Bitwize
  19. MkvToMp4 author oreons's Avatar
    Nov 2011
    Russia
    Bitwize,
    May be out of sync for a lot of reasons, I need to look at the source file. It is easier to find another source for repacking.
    ScarAce1989,
    This so that the subtitles show up bottom the window in QT player.
    joys,
    I have not found a bug
    The setting what you want is in the general tags settings.
    mstrelan,
    steve51184,
    No command-line options.
    sylance,
    You need to enable "Edit mode" for MP4 and on each audio tracks enable flags AAC Encode and Sox.
    Jan 2013
    Germany
    Hi,
    Your Tool Works GREAT! It's really awesome!
    I encountered 2 Problems. both occured after upgrading from 0.221a to 0.222.
    €dit: I downloaded the file again, now it's working *happy*
    Sorry
    But now everything works great! I Love this Tool!
    Keep it going
    Best regards,
    Chris
    Aug 2009
    hope your next release fix the audio issue! it's so low, maybe because of the conversion. Thanks! lovely tool!
  22. Question:
    What would be the optimal settings to change an mkv to mp4 for the roku2 xs?
    I cannot have h.264 level 5. I need level 4 and when I asked the program to change it to level 4 it still produced files with MPEG4-Visual and level 5.
    Any help is much appreciated
  23. First this is a great program. I use it all the time.
    One thing I would like to use it for is converting home movies that I captured on my JVC video camera. These files are in a .MOD format.
    Do you know if this would be possible to convert these types of files? The reason I would want to use this is because I wont lose any quality and the quick speed of conversion.
    Any help would be greatly appericated.
    tonybrooks
  24. Great program. I am glad to have found this. Thank you. Any way to remove the "writing application" tag?
  25. MkvToMp4 author oreons's Avatar
    Nov 2011
    Russia
    alicy,
    Use Sox checkbox in audiotrack settings for increase volume.
    rsmithjr42089,
    tonybrooks,
    I need a file sample.
    ecsjr,
    No, it's program promotion You can remove it through another application.
  26. Thanks for your quick reply.
    I have uploaded a sample file as requested. It is called MOV287.ZIP. It is a standard .MOD file that comes off my JVC video camera.
    Thanks heaps for looking into this.
    Cheers
    tonybrooks
  27. Originally Posted by oreons View Post
    ecsjr,
    I understand the need or want to promote your program. No complaints about that. As for using another program to remove it? Like once I have the .mp4 from your program run it through another program called? Just curious because I use subler to create MP4s on Mac and the resulting file does not have the "writing application" tag but under windows using YAMB (custom edition upgraded by me) and your program, both seem to stamp the programs name in the resulting file. Any help is welcomed. Again, thank you.
  28. MkvToMp4 author oreons's Avatar
    Nov 2011
    Russia
    tonybrooks,
    I will add the extension MOD in the next release. Prior to that, you can rename the extension to MPG. But your camera shoots video in interlaced scan, so when encoding converts interlace-progressive. My program does not know how to do high quality, so in video becoming effect "combing". So the video is better encode more advanced programs for this purpose, such as Sony Vegas.
    ecsjr,
    Use MetaX to edit all of tags. (http://www.danhinsley.com/metax/metax.html)
  29. I read all the pages here (some good stuff). So I don't know if I missed this:
    I made a couple m4v's from mkv's using your program (video pass through, audio AC3 pass through + AAC 2ch). The resulting files work great in all 3rd party apps (VLC, MPlayerX, etc) but only issue I have is in iTunes 11. When skipping to another chapter the video freezes but the audio is playing. This lasts about 5 seconds and then continues normally.
    The files are being played locally.
    Any ideas?
  30. oreons, thanks for your quick reply. I tried renaming the file as suggested and it allows me to convert the video. As you stated the resulting converted video has the lines through it, so I guess that is what you were talking about.
    Regarding using Vegas, its a $600 product, so a little out of my price range. That is what I loved about yours was the price but more importantly the speed at the conversion and the ease of use.
    I will keep looking around for a quick program that is easy to use.
    Thanks for all of your assistance with this issue.
    cheers
    tonybrooks
