Page 12 of 27
FirstFirst ... 2 10 11 12 13 14 22 ... LastLast
Results 331 to 360 of 809
Thread: MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4
  1. #331
    Member
    Mar 2013
    Australia
    Posts
    2
    Re: MkvТоMp4 v0.222 - rapid tool for repack Mkv to Mp4
    No one?!
    Can someone explain "repack parameters" under video settings?
    Trying to convert MKV x264 file to m4v. Audio is fine, no video. Can someone help me with settings or if I need a different source file format? Thank you.
    Hi Oreons, tanks for all your worjk, i love your program, but i have a problem with some files.
    I have the Video File A than have Auddio AAC 6Chanels and resolution 1280x720 and a File B that have Audio AAC 2 chanels and resolution of 1980x1038,
    I want to produce the File C.m4v whith tags, video resolution 1980x1038 and the 2 audios. both video files are in 23,976 FPS and the total time of the movies are same (2:01:38)
    MkvToMp4 produce a final file with total time of 2:06:30 and Audios out of sync.
    I take the temp files MKvToMp4 produces (video.264, the 2 acc and the .ttxt) and merge with MeGUI (optiom mp4 muxer) and produce a file with correct time and audios sync.
    I don´t know if some parameter makes the diference, but mp4box with the MkvToMp4 parameters import de video file with 23.000 FPS
    ---------------Log of Mkv4Mp4--------------
    Starting Mp4Box with the parameters:
    Tools\MP4Box\MP4Box.exe -new -delay 1=1 -set-meta "[:tk=2]" -set-meta "[:tk=3]"
    -add "Temp\video.264":fps=23.976:lang=eng:name="mkv.264 #trackID=1:fps=23.976@GPAC0.5.1-DEV-rev4283"
    -add "D:/test/Audio5_1.AAC"#1:fps=23.976:lang=eng:name="Ingles AAC 5.1"
    -add "D:/test/Audio2_0.AAC"#1:fps=23.976:lang=eng:name="Ingles AAC 2.0"
    -itags tool="MkvToMp4 [www.mkvtomp4.ru] version 0.222" "D:/test\File_B_new.m4v"
    AVC-H264 import - frame size 1920 x 1038 at 23.000 FPS
    AVC Import results: 174982 samples - Slices: 1678 I 54722 P 118582 B - 1 SEI - 1569 IDR
    Stream uses forward prediction - stream CTS offset: 2 frames
    AAC import - sample rate 48000 - MPEG-4 audio - 6 channels
    AAC import - sample rate 48000 - MPEG-4 audio - 2 channels
    Setting up iTunes/iPod file...
    --------------- Log of MeGUI ---------------
    -[Information] [07/03/2013 01:32:11 p.m.] Job commandline:
    "D:\AppProtable\MeGUI\tools\mp4box\mp4box.exe"
    -add "D:\test\video.264#trackID=1:fps=23.976"
    -add "D:\test\Audio5_1.AAC#trackID=1:lang=en:name=Ingle s AAC 5.1"
    -add "D:\test\Audio2_0.AAC#trackID=1:lang=en:name=Ingle s AAC 2.0"
    -add "D:\test\sub.Spanish.ttxt#trackID=1:lang=es"
    -tmp "D:\\test" -new "D:\test\video-muxed.mp4"
    -[Information] [07/03/2013 01:32:11 p.m.] Muxing started
    -[Information] [07/03/2013 01:54:25 p.m.] Standard output stream
    -[Information] [07/03/2013 01:54:25 p.m.] Standard error stream
    --[NoImage] AVC-H264 import - frame size 1920 x 1038 at 23.976 FPS
    --[NoImage] AVC Import results: 174982 samples - Slices: 1678 I 54722 P 118582 B - 1 SEI - 1569 IDR
    --[NoImage] Stream uses forward prediction - stream CTS offset: 2 frames
    --[NoImage] AAC import - sample rate 48000 - MPEG-4 audio - 6 channels
    --[NoImage] AAC import - sample rate 48000 - MPEG-4 audio - 2 channels
    Hello Oreons,
    Thanks a lot for a great conversion tool! I have converted my MKV to MP4 without error (I have checked the log), however, I cannot display the subtitles at all on my Apple TV3 or itunes. Here is the log if it helps:
    Repack/encoder video to MP4 for Apple iPhone, iPad, ATV2. MkvToMp4 version 0.222
    Build from: Nov 13 2012 18:28:21
    Use log file: Temp\Logs\16_03_2013_00_26_53.txt
    QuickTime version: 7.6.9
    CoreAudioToolbox version: 7.9.8.2
    Added on list: C:/smartget/Life.Of.Pi.2012.720p.BluRay.x264-CROSSBOW/New folder/a.mkv
    Started processing file: C:/smartget/Life.Of.Pi.2012.720p.BluRay.x264-CROSSBOW/New folder/a.mkv
    Starting Eac3To with the parameters:
    Tools\eac3to\eac3to "C:\smartget\Life.Of.Pi.2012.720p.BluRay.x264-CROSSBOW\New folder\a.mkv" 2: "Temp\a_internal_audio_0_EacID_2.wav" -down2 -phaseShift -mixlfe -normalize -down16 -progressnumbers
    MKV, 1 video track, 1 audio track, 2 subtitle tracks, 2:07:00, 24p /1.001
    1: h264/AVC, 1280x688 24p /1.001 (80:43)
    2: DTS-ES, 5.1 channels, 24 bits, 1509kbps, 48kHz
    3: Subtitle (SRT)
    4: Subtitle (SRT)
    a02 The ArcSoft and Sonic decoders don't seem to work, will use libav instead.
    a02 Extracting audio track number 2...
    a02 Decoding with libav/ffmpeg...
    a02 Downmixing multi channel audio to stereo...
    a02 Reducing depth from 64 to 16 bits...
    a02 Writing WAV...
    a02 Creating file "Temp\a_internal_audio_0_EacID_2.pass1.wav"...
    a02 Clipping detected, a 2nd pass will be necessary.
    a02 Starting 2nd pass...
    a02 Reading WAV...
    a02 Writing WAV...
    a02 Applying -1.59dB gain...
    a02 Creating file "Temp\a_internal_audio_0_EacID_2.wav"...
    a02 The original audio track has a constant bit depth of 16 bits.
    Video track 1 contains 182687 frames.
    Done.
    Starting MkvExtract with the parameters:
    Tools\mkvextract\mkvextract tracks "C:/smartget/Life.Of.Pi.2012.720p.BluRay.x264-CROSSBOW/New folder/a.mkv" 4:"Temp\video.264"
    Extracting track 4 with the CodecID 'V_MPEG4/ISO/AVC' to the file 'Temp\video.264'. Container format: AVC/h.264 elementary stream
    Starting Sox with the parameters:
    Tools\sox\sox "E:/Software/MkvToMp4_0.222/Temp/a_internal_audio_0_EacID_2.wav" "Temp\a_internal_audio_0_EacID_2_drc.wav" -S compand 0.0,1 6:-70,-43,-20 -6 -90 0.1 gain -n -0.1 treble +0.1
    Input File : 'E:/Software/MkvToMp4_0.222/Temp/a_internal_audio_0_EacID_2.wav'
    Channels : 2
    Sample Rate : 48000
    Precision : 16-bit
    Duration : 02:06:59.62 = 365741568 samples ~ 571471 CDDA sectors
    File Size : 1.46G
    Bit Rate : 1.54M
    Sample Encoding: 16-bit Signed Integer PCM
    Done.
    Starting Qaac with the parameters:
    Tools\qaac\qaac --quality 2 --ignorelength --tvbr 95 "E:/Software/MkvToMp4_0.222/Temp/a_internal_audio_0_EacID_2_drc.wav" -o "Temp\a_internal_audio_0_EacID_2_drc.m4a"
    initializing QTML...done
    qaac 0.86, QuickTime 7.6.9
    MPEG-4 AAC Encoder 1.7.1, Variable Bit Rate q91, Best
    365741568/-1 samples processed in 02:37.514
    Overall bitrate: 175.791kbps
    Tools\Mp4Box\Mp4Box -TTXT "E:/Software/MkvToMp4_0.222/Temp/a_external_sub_0.SRT"
    Timed Text (SRT) import - text track 400 x 60, font Serif (size 18)
    Conversion done
    Tools\MP4Box\MP4Box.exe -new -delay 1=1 -add "Temp\video.264":fps=23.976:lang=eng:name="" -add "E:/Software/MkvToMp4_0.222/Temp/a_internal_audio_0_EacID_2_drc.m4a"#1:fps=23.976:l ang=eng:name="" -add "E:/Software/MkvToMp4_0.222/Temp/a_external_sub_0.ttxt":lang=eng:name="" -itags tool="MkvToMp4 [www.mkvtomp4.ru] version 0.222" "C:\smartget\Life.Of.Pi.2012.720p.BluRay.x264-CROSSBOW\New folder\a.mp4"
    AVC-H264 import - frame size 1280 x 688 at 23.976 FPS
    AVC Import results: 182687 samples - Slices: 1147 I 55208 P 126332 B - 1 SEI - 1107 IDR
    IsoMedia import - track ID 1 - Audio (SR 48000 - 2 channels)
    Timed Text (GPAC TTXT) Import
    Saving C:\smartget\Life.Of.Pi.2012.720p.BluRay.x264-CROSSBOW\New folder\a.mp4: 0.500 secs Interleaving
    Correction mp4 file.
    TKHD atom correction for video. TRAK 1
    TKHD atom correction for audio. TRAK 2
    Writing tags in file: C:\smartget\Life.Of.Pi.2012.720p.BluRay.x264-CROSSBOW\New folder\a.mp4
    Open result file C:\smartget\Life.Of.Pi.2012.720p.BluRay.x264-CROSSBOW\New folder\a.mp4 for test.
    The file <b>C:/smartget/Life.Of.Pi.2012.720p.BluRay.x264-CROSSBOW/New folder/a.mkv</b> is processed successfully
    File processing time: 13 min. 17 sec.
    Total time: 13 min. 17 sec.
    Thanks in advance and best regards
    MkvToMp4 author oreons's Avatar
    Nov 2011
    Russia
    Posts
    157
    augustosanchez,
    Maybe because of different versions mp4box in programs.
    ronch,
    To display subtitles, you need to use the m4v format.
    Nov 2011
    Russia
    Posts
    157
    MkvToMp4 0.223 http://www.mediafire.com/?4645ian266lzjy0
    New in version:
    1. Selecting iTunes country to search tags. You can select country in settings, it will be by default. Also available the selection at the search dialog.
    2. Update utilities in the folder Tools: MkvExtract, Qaac, FFMpeg, Mp4Box, Eac3To
    3. The original name of the movie stored to the tag SortName.
    4. Russian ratings in tags.
    5. Fixing bugs in rating, delay and reencoding AAC.
    6. Removing private user information from the movies.
    Re: MkvТоMp4 v0.223 - rapid tool for repack Mkv to Mp4
    Just keeps getting better
    Feature Request:
    I would love to see the ability to select all videos and check optimize.
    Thanks,
    Chris
    Thanks Oreon, just one thing, it is possible, to change the font and size of the font for the subs ?
    Nov 2011
    Russia
    Posts
    157
    Redneck,
    For Apple devices in a standard player it's impossible. In soft players can choose subtitle options.
    Quote Originally Posted by oreons View Post
    Redneck,
    Thanks for the answer, another thing, since a while, everytime a try to add a subtittle and tags to a movie file, the result file has the audio out of sync, even if the original file is perfectly sync, i didn't touch the video nor audio stream (the original is AAC) just add the subs i think this start when i update itunes but i don't know for sure.
    Any comment's will be appreciated.
    I am having problems trying to convert my mkv's to mp4's for apple tv3 playback. I am not sure what settings to choose with this program.
    I am trying to include an AAC (stero) and AC3 passthrough tracks as most of my MKV's have DTS audio. However I have no idea what settings to choose for audio and video (the appletv drop down doesn't seem right for some reason) Does anyone have a guide?
    I was using Handbrake, but it also encodes the video which can take hours...
    Nov 2011
    Russia
    Posts
    157
    Redneck,
    Audio desync is not associated with subtitles and tags, the reasons can be many. It is better to find another source.
    kickitinold,
    On DTS: mouse double click on audio track and set "Create AC3 track" checkbox.
    Hi Oreons
    I test te audio sync problem with the same m4box program (MkvToMp4 0.223) and the problem is with the line of comand.
    i have been converting my colecction of MKVs and MP4 to M4v (With subtitles included and tag info), for each 15 files 1 have the sync problem
    --------------------- Command line generated for MkvToMp4 ---------------------
    "D:\AppProtable\MkvToMp4_0.223\Tools\MP4Box\MP4Box.exe"
    -new -delay 1=1 -set-meta "[:tk=2]" -set-meta "[:tk=3]" -set-meta "[:tk=4]"
    -add "D:\V\Clerks2\video.264":fps=23.976:lang=eng:name= "2.2006.1080p.BrRip.x264.BOKUTOX.YIFY.264#trackID= 1:fps=23.976@GPAC0.5.1-DEV-rev4283"
    -add "D:\V\Clerks2\Clerks 2 (2006) [1080p]_internal_audio_2.AAC"#1:fps=23.976:lang=eng:name= "Ingles AAC 2.0"
    -add "D:\V\Clerks2\Clerks 2 (2006) [1080p].Spanish_external_sub_0_utf8_change.ttxt":lang=spa :name="Esp. Latino"
    -add "D:\V\Clerks2\Clerks 2 (2006) [1080p].English_external_sub_1_utf8_change.ttxt":lang=eng :name="Ingles"
    -itags tool="MkvToMp4 [www.mkvtomp4.ru] version 0.223" "D:/V\Clerks2\Clerks 2 (2006) [1080p]_new.m4v"
    -tmp "D:\AppProtable\MkvToMp4_0.223\Temp/Mp4Box"
    The answer in the command line is:
    AVC-H264 import - frame size 1920 x 1080 at 23.000 FPS
    AVC Import results: 140354 samples - Slices: 1408 I 38471 P 100475 B - 1 SEI - 1
    322 IDR
    Stream uses forward prediction - stream CTS offset: 3 frames
    Saving D:/V\Clerks2\Clerks 2 (2006) [1080p]_new.m4v: 0.500 secs Interleaving
    and this is the info generated for MediaInfo of the video track
    Video
    Formato : AVC
    Formato/Info : Advanced Video Codec
    Formato del perfil : High@L4.0
    Ajustes del formato, CABAC : Si
    Ajustes del formato, RefFrames : 3marcos
    ID Códec : avc1
    ID Códec/Info : Advanced Video Coding
    Duración : 1h 41min.
    Tasa de bits : 1 811Kbps
    Tasa de bits máxima : 11,4Mbps
    Ancho : 1 920pixeles
    Alto : 1 080pixeles
    Relación de aspecto : 16:9
    Modo de velocidad de cuadro : Constante
    Velocidad de cuadro : 23,000fps
    Velocidad de cuadro Original : 23,976fps
    ColorSpace : YUV
    ChromaSubsampling : 4:2:0
    BitDepth/String : 8bits
    Tipo de exploración : Progresivo
    Bits/(Pixel*cuadro) : 0.038
    Tamaño de pista : 1,23GIB (95%)
    Título : .2006.1080p.BrRip.x264.BOKUTOX.YIFY.264#trackID=1
    Librería de codificación : x264 core 129 r2245 bc13772
    Opciones de codificación : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=1 / b_adapt=2 / b_bias=2 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=1811 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Idioma : Inglés
    Fecha de codificación : UTC 2013-03-24 16:42:05
    Fecha de la etiqueta : UTC 2013-03-24 16:43:01
    I notice 2 things:
    1. the fps original are 23.976 and the fps of this track is 23.000
    2. The Title of the movie is ".2006.1080p.BrRip.x264.BOKUTOX.YIFY.264#trackID=1 " but in the command line you put "2.2006.1080p.BrRip.x264.BOKUTOX.YIFY.264#trackID= 1:fps=23.976@GPAC0.5.1-DEV-rev4283"
    for thats diferences i think the problem is in the command line of the video track, and then test this command
    -------------------------------- Command that work fine -----------------------
    "D:\AppProtable\MkvToMp4_0.223\Tools\MP4Box\MP4Box .exe"
    -add "D:\V\Clerks2\video.264":fps=23.976:lang=eng:name= "Video"
    If you see, the only change was in the name of the video track and the result of the file is ok, here is the answer of the command line
    AVC-H264 import - frame size 1920 x 1080 at 23.976 FPS
    322 IDR
    Great program, but I've noticed the following issues:
    Whenever you finish searching for tags, it unchecks the "MP4 Optimization" checkbox, even if you have it set in the config, and you've previously checked it.
    It looks like you should be able to select images to automatically add to the file, but this doesn't work. The only way I can get an image into the file is to right click on one of the images, save it to disk, then manually attach it.
    Saving an image to disk fails if the filename the program wants to use contains an invalid character for a filename like ":".
    Oreon, cheking With more detail, o notice Youtube Put in The video track name, The same of The original file. And for some reason, m4box import The video at 23.000fps With The kind vido track names i show Youtube in The previos message.
    Cómodo you Put in you next version an opción to edit The video track name, like The audio and subtitle tracks has.
    Nov 2011
    Russia
    Posts
    157
    augustosanchez,
    In the properties of the video track, set the correct fps manually.
    Why do it?
    kingmotley,
    With optimization, yes, there is. Do the search first.
    Oreons,
    Selecting the image and clicking save does nothing. It does not show that it is going to add any artwork, and if I let it process the file, it will not add it either.
    Ho Oreons
    I Put in The in The video track The correct fps, if you look in The previous message, The command generated for MkvToMp4, Put in The video and audio tracks 23,974fps (correct fps)
    Why do it?
    Because in The same example I Put in The previous message, The original video track has a name With references to fps, that make m4box import The video track With bad fps (23,000).
    Always i have a file to convert that in The name of the video track has info like "2.2006.1080p.BrRip.x264.BOKUTOX.YIFY.264#trac kID= 1:fps=23.976@GPAC0.5.1-DEV-rev4283", Your Program Put The same text in The name of The video track and The m4box import The video track With bad fps. I have Many video files With that kind of text in his video track name
    I solve The problem changing The name of The video track in The command line (example in The previous message)
    For that reason if i could change The video track name in MkvToMp4, i don't need to stop The Program in The moment it's bulding The final file and use The command line.
    Nov 2011
    Russia
    Posts
    157
    kingmotley,
    Try to move the program to another directory (writable).
    augustosanchez,
    Need an example of your file for the test. I checked the track named ".2006.1080p.BrRip.x264.BOKUTOX.YIFY.264#trackID=1"
    and it worked correctly.
    Tools\MP4Box\MP4Box.exe -new  -set-meta "[:tk=2]" -par 1=980:1000  -add "Temp\video.264":fps=23.976:lang=eng:name=".2006.1080p.BrRip.x264.BOKUTOX.YIFY.264#trackID=1" -add "MkvToMp4/Temp/frozzen_internal_audio_2_new.m4a"#1:fps=23.976:lang=rus:name="Dublirovannoe [Licenzija]" -itags tool="MkvToMp4 [www.mkvtomp4.ru] version 0.224Test1" "E:/Kino\frozzen.m4v" -tmp "Temp/Mp4Box"
    Oreons, check With a track named "2.2006.1080p.BrRip.x264.BOKUTOX.YIFY.264#trac kID= 1:fps=23.976@GPAC0.5.1-DEV-rev4283" and you see The problem.
    Member
    Mar 2013
    Texas
    Posts
    90
    Problem with randomly enabling VFR? I say random, because just for giggles, I added a sub to an .mp4 (same files each time) 10 times. Out of those 10 times, 3 of them resulted in this happening....
    Started processing file: C:/Users/Tim/Videos/Django Unchained.mp4
    Tools\Mp4Box\Mp4Box -raw 1 -out "Temp\video.264" "C:/Users/Tim/Videos/Django Unchained.mp4"
    Extracting MPEG-4 AVC-H264 stream to h264
    Tools\Mp4Box\Mp4Box -raw 2 -out "Temp\Django Unchained_internal_audio_2.AAC" "C:/Users/Tim/Videos/Django Unchained.mp4"
    Extracting MPEG-4 AAC
    Tools\Mp4Box\Mp4Box -TTXT "C:/Program Files (x86)/MkvToMp4/Temp/Django Unchained_external_sub_0.SRT"
    Conversion done
    Tools\MP4Box\MP4Box.exe -new -delay 1=1 -add "Temp\video.264":fps=23.976:lang=eng:name="unchain ed.2012.1080p.bluray.x264-sparks.mkv.264#trackID=1:fps=23.976@GPAC0.5.1-DEV-rev4283" -add "C:/Program Files (x86)/MkvToMp4/Temp/Django Unchained_internal_audio_2.AAC"#1:fps=23.976:lang= eng:name="" -add "C:/Program Files (x86)/MkvToMp4/Temp/Django Unchained_external_sub_0_change.ttxt":lang=eng:nam e="":hdlr=sbtl -itags tool="MkvToMp4 [www.mkvtomp4.ru] version 0.223" "D:/Movies\Django Unchained_new.mp4" -tmp "Temp/Mp4Box"
    AVC-H264 import - frame size 1920 x 800 at 23.000 FPS
    AVC Import results: 237909 samples - Slices: 2127 I 65872 P 169910 B - 1 SEI - 2018 IDR
    Saving D:/Movies\Django Unchained_new.mp4: 0.500 secs Interleaving
    TKHD atom correction for subtitle. TRAK 3
    Writing tags in file: D:/Movies\Django Unchained_new.mp4
    Open result file D:/Movies\Django Unchained_new.mp4 for test.
    The file <b>C:/Users/Tim/Videos/Django Unchained.mp4</b> is processed successfully
    File processing time: 3 min. 48 sec.
    Total time: 3 min. 49 sec.
    Opening resulting file in MkvtoMp4 again, shows a VFR (23.000 fps) source. Easy fix, put it back to constant at 23.976, and voila, what you wanted in the first place. Anyway, would be nice to not have to do it twice to get it the result you want?
    Nov 2011
    Russia
    Posts
    157
    augustosanchez,
    dakon720
    Try this version https://dl.dropbox.com/u/7183431/0.224Test/3/MkvToMp4.exe
    (Replace mkvtomp4.exe)
    Member
    Mar 2013
    Texas
    Posts
    90
    Will try as soon as possible and report back, thank you
    Oreons,
    I test and works fine.
    Tanks
    Quote Originally Posted by augustosanchez View Post
    Oreons,
    Tanks
    But now, the name of the audio and subtitle tracks changed
    For example i put in the name of audio track "Esp. Latino AAC 5.1" and in the final file the result is "Esp__Latino_AAC_5_1", I don´t like it.
    Please, could you let the handled of audio and subtitle tracks name like in version 0.223
    Member
    Mar 2013
    Texas
    Posts
    90
    I got a chance to test it, takes care of my issue.
    @Oreons: It was in a directory that was writable, however, I tried moving it to another directory (N:\mk4tomp4), and it still didn't work, so I put a video together showing you the issues:
    1) Mp4 optimizations turning itself off.
    2) First time I go in, there is only 17 artworks available, the iTunes one doesn't show.
    3) I select one anyway, and the artwork doesn't appear.
    4) When I go back in, now 18 artworks are available, including the iTunes one.
    5) I select the iTunes artwork, however, it doesn't show on the main screen either.
    I think the last "save" click didn't show in the video, however, it didn't show up when I did.
    Here is a link to the video: https://www.dropbox.com/s/j0m6jrmat1p26nl/mkvtomp4.m4v
    Member
    Mar 2013
    Texas
    Posts
    90
    Just to chime in, in testing, I can optimize an .mp4 by ticking the box AFTER I search the tags/cover art and add it. If you tick it prior too, it un-ticks for some reason.
    As far as the artwork, I have randomly had the same problem. But seeing as how I save most of my cover art and edit the dimensions, it's not a problem for me. It's always the first artwork in the list (iTunes) that does it to me. Sometimes i'll get the generic logo, other times it will be blank, specifying 0x0 as it's size, sound familiar?
    I guess one question is, if I add art work through the search, should I see it on the main screen similar to as if I manually added the art work from a file? I'm not seeing it, and re-encoding these files with different options takes a while to see if it actually will add the art work or not.
  1. MKV Compression to a smaller MKV or MP4
    By THRobinson in forum Video Conversion
    Last Post: 20th Jul 2018, 10:56
  2. Replies: 35
    Last Post: 17th Dec 2016, 07:38
  3. MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
    By Baldrick in forum Newbie / General discussions
    Last Post: 29th Jun 2012, 11:19
  4. muxing .264 stream to .mkv, or to .mp4 first, an then to .mkv ?
    By codemaster in forum Video Conversion
    Last Post: 20th Sep 2011, 20:50
  5. Replies: 1
    Last Post: 1st Feb 2008, 03:10
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
