I am trying to understand all of the tricks to render for DVDArchitect. Before when I used the TMPGEnc.DVD.Author I extracted the video and created a file with the .m2v entension. According to advice on forums I should render using Save as type: Main Concept MPEG-2 and Template: DVD Architect PAL video stream but what extension should the file have? And the audio - should it be .mpa or .ac3?
Results 1 to 15 of 15
If you have Vegas (Pro 11 version for example) you'll find the info in the program online help section under Rendering Projects for use in DVD Architect.
Yes, I have seen that but when I set the parameters as I said before the video file gets an extension of .mpg and I wonder if that is correct.
Yes, then DVD Architect does not recompress your file, when you make a DVD.
as per your description, hope you are rendering with Main Concept MPEG-2 and DVD Architect PAL video Template... which is OK.
you can include audio in output.mpg. by default Vegas and almost all other professional softwares renders audio to MPEG Layer -II.
The file extension for MPEG Layer -II Audio is .mp2, neither .mpa nor .ac3.
So, audio - should it be .mp2
All professional DVD authoring softwares including DVD Architect supports Dolby Digital, DTS, PCM(uncompressed audio), MPEG-1 Layer-II audio. This is exactly what the DVD specification is.
That's the point, but you need to know what audio files your particular software accepts. Program specifications usually help.
@vkmast
u r really mast, i mean genius.
coz i still remember once i bought expensive software called DVDNoAuthor Professional which did not accept DTS and Ac-3. I relalized after going through program specifications only coz there was no information on internet.
I guess there are two types of software developers....
first type is they know exactly what they are coding - creating....
rest do not know what they are coding or creating or they just even do not know what are the specifications???
neway i like only first type,,,,
Have FuN!
I can't get this right. I am trying to render as follows:
Main Concept MPEG-2(*.mpg;*.m2v;*.m2t;*.mpa)
=DVD Architect PAL video stream
but what extension should the file have, .mpg, .m2v, m2t, mpa?
I have tried both .mpg and .m2v but then DVDA want to recompress the file. -
I'm new to DVDA so I didn't realize that the output format was set to NTSC. I changed it to PAL and now it responds with no recompression messages. Thanks!
Need help - rendering in Vegas
By Rairun in forum Newbie / General discussionsReplies: 4Last Post: 21st Jul 2011, 19:51 -
Vegas 8 vs Vegas 10 rendering MPG2
By schematic2 in forum EditingReplies: 0Last Post: 3rd Feb 2011, 14:32 -
Vegas 8/8.1/9 crashes when rendering on I7 (HD)
By rethox in forum EditingReplies: 0Last Post: 18th May 2009, 06:41 -
Rendering with Vegas 8
By seven1970 in forum EditingReplies: 27Last Post: 23rd Feb 2009, 12:44 -
Vegas 8 rendering problem
By rotis in forum Newbie / General discussionsReplies: 18Last Post: 21st Feb 2008, 06:27
