I need is to filter mpeg-2 to reduce the blocking and other artifacts caused by the compression. For my use the images are just data, I don't care much about the typical viewing qualities and I separate the fields to get 720x240 60Hz video. My attempts to reduce compression artifacts have gone poorly. While mpeg-2 is what I am given as input I don't have to use it for output. Many problems are just a few seconds long so uncompressed is an option.
1. Which tool (Avisynth, VirutalDub-Mod, AviDemux, Handbrake, etc. should I concentrate on? (using Win7 x64)
2. Is there a site or link that will provide a long description or review of the filters that are avalable?
3. Would someone point me to a place to read more about filtering mpeg-2?
http://www.virtualdub.org
Download and install this program.
http://compression.ru/video/deblocking/index_en.html
unzip the included file, ending in *.vdf, into the plugins directory, from the above program.
Get the mpeg2 plugin for virtualdub
http://home.comcast.net/~fcchandler/Plugins/MPEG2/
Install it. Now you can open our video. Go to filters, add, select MSU deblocking, OK, adjust some settings according to the manual, etc.
The right hand side video shows the processed version.
I'm skipping the step-by-step instructions, play with it and if you can't figure it out, you can ask further. -
Thanks, the MSU link is very interesting. I'll study it and make some tests.
scientific atlanta cable box explorer 2000
By Darkcast in forum DVB / IPTVReplies: 1Last Post: 13th Mar 2011, 14:49 -
Scientific Atlanta 8240HDC Question
By Gunstra in forum Newbie / General discussionsReplies: 3Last Post: 16th Jun 2010, 23:29 -
New to video programming, need guidance
By iangard in forum ProgrammingReplies: 0Last Post: 28th Apr 2010, 09:48 -
Guidance needed to encode an anime video to HD quality
By cybertron91 in forum Newbie / General discussionsReplies: 1Last Post: 5th Oct 2008, 23:02 -
Scientific Atlanta HD Cable Box / HDMI Audio Problem
By culttvguy in forum DVB / IPTVReplies: 5Last Post: 14th Sep 2008, 16:48
