I use DVDauthergui(mkv to mpeg then make dvd),
dvd i working fine but subtitle is not there ?
Did you add the subtitle in dvdauthorgui? Extract the sub with mkvextractgui-2 from the mkv
Did you enable the subtitle in the dvd player? If using a software player you must play the real dvd by opening the dvd folder with for example MPC.
make subtitle for learning video
By seyyed in forum SubtitleReplies: 1Last Post: 2nd Oct 2011, 08:06 -
help how i can get subtitle from any video?
By simonrule in forum SubtitleReplies: 7Last Post: 11th Oct 2009, 13:40 -
the video cant play with the subtitle
By TheEmperor in forum Software PlayingReplies: 4Last Post: 20th Sep 2009, 18:00 -
The best Video Subtitle.
By TopZoom in forum SubtitleReplies: 6Last Post: 14th Nov 2008, 09:35 -
How to add subtitle to a video
By Chuba753 in forum SubtitleReplies: 7Last Post: 7th Jun 2008, 21:31
