It isn't near double for GOP based compression because of motion correlation frame to frame. Pro shooting technique reduces pixels in motion frame to frame allowing high interframe compression. This would be less true for high action hand held. In that case less interframe compression is possible so the encoder compensates with more intraframe compression.
Formats like AVC-Intra (intraframe compression only) need to use twice the bit rate vs GOP based formats like XDCAM-EX.
Results 31 to 33 of 33
http://www.kiva.org/about -
BTW I can't make my Sony BDP-BX37 (BDP-S370) play 1920x1080 60p with AVC codec but it does play 60p MPeg2 from a USB drive.
Not true at all, you probably have not tested this.
In a occasions while encoding video to 30p or 60p (30p from Vegas and then same video to 60p through mvtools2.dll) I forgot to change bitrate inside encoder and my human eye did not registered that at all. Then I played with it for a while, ..., to double bit rate is a waste, that was a conclusion of it. To find how much to add I do not know, it will differ from video to video.
HD Video File ( 1080 50P ) from Panasonics TM700
By wisitch in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 22nd Aug 2011, 09:45 -
AVCHD Spec Version 2.0 Updated 1080/60p , 50p
By poisondeathray in forum Latest Video NewsReplies: 6Last Post: 8th Jul 2011, 03:45 -
Signal System : 1080/50p , 1080/50i on HDC-SD700
By wisitch in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 22nd Sep 2010, 09:11 -
1080/60p camcorder output via HDMI into Mac
By Trilomac in forum Newbie / General discussionsReplies: 18Last Post: 28th Jan 2010, 21:42 -
1080/29.97psf with 2:2:2:4 cadence back to 1080/23.98p, how?
By metalvic20 in forum Video ConversionReplies: 0Last Post: 17th Dec 2008, 14:28
