I haven't done the multiregion hack, so I can't comment if it works after the FW upgrade.
However, SVCD subtitles work a lot better after the update. No more player freezes and the subtitles display correctly (they disappear when there's no coversation). Also, some SVCDs (without subtitles) that previously had playback problems (freezing for a while on some spots) now play correctly.
Results 31 to 37 of 37
Originally Posted by rock122
I had the same problem I fix it with the new Nero 5572 and Unlead DVD to burn SVCD's FF RW work fime now
so could I just use a small svcd then put mine in? also could you give me what you did for making it work with ulead and nero
Ladies and Gentelmen I would like to thank everyone who contributed and helped me especially duck712 who at last solved it for me. Since I had to put a svcd with lower than 36 min. in it I just put in a failed svcd that had like 3 seconds and all others work after.
Originally Posted by del3165
1-you have a Philips 711
2-You have burnt a SVCD with nero and TMPG
3-The SVCD you burnt does FF on the Philips 711
If alla the answers are yes, please tell us
-Do the SVCD has more than 40 min?
-Which version of Nero did you use ?
Giuliano -
Me too have a Philips 711 DVD, with 7.22 bios
What did you mean wit " I put in a failed svcd that had like 3 seconds and all others work after" ??!!??
Can you better explain wath did you do ?
By the way, I've done some tests with my 711, and I discovered that:
-the SVCD sample on www.vcdhelp.com works with 2 audio and subtitles.
-SVCDs shorter than 40 min do ff and rew (I used the same test).
-SVCDs longer than 40 do "time jump" from the menu (i.e. I can ff entering the time I need to reach)
-SVCDs longer than 40 cannot ff but can slow forward (strange, isn't it?)
Giuliano
Fast forwarding and rewinding a tape before capture?
By justin81 in forum RestorationReplies: 4Last Post: 14th May 2010, 16:41 -
Video freezing when fast-forwarding.
By xcodyj in forum Newbie / General discussionsReplies: 1Last Post: 4th May 2010, 03:45 -
Viewing during VCR fast forwarding/rewinding
By spinmonk in forum Capturing and VCRReplies: 12Last Post: 30th Aug 2009, 18:30 -
ogm's fast forwarding
By CommanderZero in forum Newbie / General discussionsReplies: 2Last Post: 21st Oct 2007, 23:23 -
fast forwarding flvs with vlc?
By majax79 in forum Software PlayingReplies: 2Last Post: 20th Sep 2007, 13:54
