Hi
sorry to shout out but trying to encode to dvd using the settings i think are correct and get the following error message:
creation_time : 2011-09-01 16:11:13
Stream #0.2(eng): Data: tmcd / 0x64636D74, 0 kb/s
Metadata:
creation_time : 2011-09-01 16:11:14
Unknown input format: 'dvd'
my settings are below and any help would be greatly appreciated:
-f dvd
-acodec ac3
-ab 448000
-ar 4800
-b 7000000
-s 720x576
-r 25
-vf setdar=16:9
-aspect 16:9
-vcodec mpeg2video
-qmin 2
-qmax 31
-async 1
-i fichierentree
-pass 2
-passlogfile ffmpeg2pass fichiersortie -2
the last three were my attempt at setting a 2pass encode
any pointers would be greatly appreciated
thank you
Closer inspection reveals some errors in the syntax:
* input file should be specified before output options.
* -ar 4800 should be -ar 48000 (48 kHz audio)
* the "-2" at the end makes no sense to me? Neither to ffmpeg...
* do pass 1 first, then pass 2; you can't set both in one command (see below)
And some minor things:
* -vf setdar=16:9 and -aspect 16:9 do the same thing (not a real error, but redundant)
* -qmin 2 -qmax 31 is about the whole quantizer range. More useful would be a restriction, e.g. -qmin 2 -qmax 20 would set a comfortable qmax for limiting compression, thereby not allowing too much degradation from compression.
Assuming interlaced content, you may need to set the field order, as DV is bottom field first (bff) and MPEG-2 is top field first (tff).
-vf "fieldorder=bff" or -vf "fieldorder=tff", not sure which for DV > MPG. (The example from the ffmpeg docs list -vf "fieldorder=bff" for VOB > DV.)
Two pass conversion:
* The first pass may ignore audio (-an), as the two pass routine works on the video.
* The output of the first pass may be nulled (-y /dev/null or -y NUL), as you only need the passlogfile. The second pass will write the actual output (output.mpg)
Code:ffmpeg -i input.mov -f dvd -an -b 7000000 -s 720x576 -r 25 -vf "setdar=16:9" -vcodec mpeg2video -qmin 2 -qmax 20 -async 1 -pass 1 -passlogfile ffmpeg2pass -y /dev/null ffmpeg -i input.mov -f dvd -acodec ac3 -ab 448000 -ar 48000 -b 7000000 -s 720x576 -r 25 -vf "setdar=16:9" -vcodec mpeg2video -qmin 2 -qmax 20 -async 1 -pass 2 -passlogfile ffmpeg2pass output.mpg
How do I pick settings to optimally re-encode video for reduced file size?
By bootyhound1 in forum Video ConversionReplies: 1Last Post: 13th Jan 2012, 15:16 -
settings to encode video for sanyo incognito
By tater1969 in forum Portable VideoReplies: 0Last Post: 26th Apr 2010, 08:10 -
OS X Issue - converting DVD to, well, pretty much anything!
By phelan74 in forum DVD RippingReplies: 0Last Post: 18th Jan 2009, 22:09 -
Not free but pretty good converter for MKV to other formats, including DVD
By moviebuff2 in forum Video ConversionReplies: 0Last Post: 27th Dec 2007, 07:04 -
A pretty good DVD library manager
By NeilH in forum Newbie / General discussionsReplies: 0Last Post: 8th Oct 2007, 14:23
