  1. HI,
    can anybody help me with my problem with DVDit 2.3 PE. When I try to create a dvd folder, it show up a pop-up menu and didn't have any error and when I close it, it said that " Failed to build a DVD in folder: " This is a pain in the azz since I have spending time alot of my effort making the layouts and converting the video and audio to compatiable with DVDit. Please help the brother out. Thankz
    PS: here is the link to show the picture that show the error.
    http://www.familyshoebox.com/family/702/FSLO-1017001992-853702.jpeg
  2. this has happend to me using various versions of sonic a few times. Mainly it concerned the bitrate used for the clip whta is it at( if its variable do you recall what you had the high setting to ex: 9.5, etc). This may be the cause as sonic has dvd bitrate limits-finally though the newer 2.5 for the PE allows a 9.8 though i sitll have clips that hit 10
  3. thank for the reply.
    I have found out the problem, I misplace the video source file so it didn't recognize the file.
    Now, there is a new problem. When I have almost create the folder, during the Project AUDIO/SPU, it said " Inconsistent audio type " wat does it mean? Help ???
