On some packaging for blank DVD media I see a stylized "RW" logo. What does it mean? I'm not talking about the RW that signifies rewritable discs. This logo is pretty small and inconspicuous.
It is the logo for the DVD+RW Alliance, the group of companies which developed the standards used for DVD+R, DVD+R DL and DVD+RW media.
usually_quiet is correct. Please note that although this was not done in the past, in recent years the Alliance has put this logo on DVD+R disc packages and some consumers have incorrectly concluded that their DVD+R discs were actually DVD+RW.
Yea, I noticed that too. Some guy goes by PA Bear on Tech Support group said Toshiba won't let the DVD+RW Alliance group use the regular DVD logo, so they chose the little RW Logo. It doesn't mean Re-Writable (in this context). paj692
PC "thinks" burned media is blank
By joelson in forum MediaReplies: 12Last Post: 28th Jan 2012, 19:19 -
AVStoDVD does not start... says "VB6 Common Controls not found!"
By granturissimus in forum Newbie / General discussionsReplies: 2Last Post: 12th Jan 2011, 08:15 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
Samsung R155 DVD Recorder - "Recorded" or "Blank"?
By mhamini in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Feb 2010, 20:01 -
Any Program to "blank out" or "black out" a portion of
By mbextreme in forum EditingReplies: 6Last Post: 18th May 2007, 05:04
