I have allot of home videos. I have done it before but am having problems using the TDK DVD-R discs. I have copied a short movie from VHS to a DVD-R disc. It plays fine on the DVD recorder with TV. However, when I put the DVD into my computer, my drive does not recognize it.
Does anyone know what am I doing wrong.Also, is there a way to add 4 short VHS home movies and put them all on one DVD-R disc?
A couple years ago I was successful making my movies but I used Sony DVD+RW discs. But I would rather use these TDK DVD-R discs if possible since I have so many.
you must "finalize" the dvd-r discs for them to play in other devices
You should be able to use your DVD recorder to add to a DVD-R that has not yet been finalized, if there is still enough room for more recordings.
If you still have your movies stored on DVD-RW, you should copy them to DVD-R or DVD+R discs as soon as possible. Re-writable media is only good for temporary storage. The recording layer of re-writable DVD media is a phase-change material. It will eventually return to its original state over time, and the data contained on the disc will be lost. -
Dear october262:
I was trying to finalize the dvd-r. I must be using the wrong method. I put the DVD-R in my DVD drive on my computer and it does not read it or acknowledge the DVD is in the player.
Do I finalize it from my PC or while it is still in the VHS/DVD recorder? -
You have to finalize the disc in the recorder that 'created' it.
(Edit: just a moment too slow
If cameras add ten pounds, why would people want to eat them? -
Thank you Mike and Ai: Okay I will need to finalize it in the DVD recorder. However, I only have 30 min. of a short movie in Chapter 1 of the DVD and I want to fill the DVD with more before I finalize the DVD. This is where I am coming into difficulties. When I am on the next video frame, I put the next short VHS movie into the VCR and I click "Play" and then I click the "Dubbing" button just like I did when I copied the first movie, but for some reason, the Dubbing button blinks a few time and then stops and will not copy. Does anyone know why?
Well these DVD-R's are doing what I want them to do in the recorder so I am going to go another route. I am going to try to make a full DVD+RW of family videos and then try copying the DVD+RW to a DVD-R. I hope this works.
Recorded DVD picture jumps, original VHS source doesn't
By bigj7489 in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2010, 09:09 -
By bigj7489 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 25th Jun 2010, 20:59 -
overwatched/stretched VHS recorded fr TV;possible to restore/burn on DVD?
By CAWills in forum RestorationReplies: 4Last Post: 22nd Dec 2008, 13:16 -
Recent home videos (VHS) recorded to DVD & now in Mpeg2...
By tehfreeman in forum DVD RippingReplies: 7Last Post: 19th Dec 2008, 14:12 -
VHS tape recorded in England
By lolabragg in forum Newbie / General discussionsReplies: 2Last Post: 17th Jun 2007, 22:05
