Anyone encountered issues with locked MKV files? Some of the movies on my computer appear locked by 3-7 instances of explorer and really slow down performance. I downloaded Unlocker (which is how I noticed this) however that only helps with renaming/moving/deleting. It does not remove the problem as it once again gets locked after renaming/moving. Plus the multiple instances of explorer greatly slow down my PC, that even unlocker comes up after a whole minute if not more.
1) I read numerous posts saying that the issue is that this particular MKV is corrupt/damaged, even though it plays fine. I've tried to repair this file with Meteorite, and MKVToolnix, but it does not solve the problem and in some cases even gets worse. So I've verified that this is NOT the issue.
2) Other posts say the issue is with explorer's thumbnail creation, and it takes too long with files that are 10GB and more. I don't really care about the thumbnails for vids, but I don't want to disable thumbnails altogether, in cases of JPG files and such. Besides that's not really a solution.
3) And third set of posts say the issue is with explorer trying to figure out the length/duration of the file and where it ends... which is causing the lag similarly to #2 above. In this case they mention there's a DivX fix out there, which I've downloaded and installed but it does NOT fix the issue either.
Anyone experiencing the same thing? Know how to resolve it? I repeat again the issue here is NOT with a corrupt MKV file, and not with my hardware, as I can play any other HD MKV file just fine. It's only the selected few that always cause this issue.
Hardware Specs
CPU: Intel Core2Duo E4500
RAM: 4GB DDR2
GPU: Radeon HD 4xxx Series
There's another possible cause of this found here (last post):
http://answers.microsoft.com/en-us/windows/forum/windows_7-files/mkv-files-are-locked-...e-8eb4620547c3
Not sure if I want to mess around with my registry, but I figured maybe it would give whoever is reading this more info to help me. Please let me know what you think.
"The source of this problem is DivXPropertyHandler.dll attempting to determine the length of .mkv files. Windows 7 decides to automatically add the length column in detail view when there is a large amount of video files. Given a .mkv file DivXPropertyHandler.dll doesn't like (for whatever reason), the explorer handle on that .mkv will hang when DivXPropertyHandler.dll is unable to determine the length of that .mkv. And thus the file is locked." -
Wow seems like no one here can be of any help. After some more googling, it appears that DivXPropertyHandler.dll was in fact the culprit. I uninstalled DivX from my PC and the issue disappeared. Media Player Classic Home Cinema edition already comes with a built-in plugin to play most video files, including MKV, and the files play just fine without needing DivX at all. The other option was to install K-Lite Codec Pack Standard, which would enable video playback for virtually all video types and would not involve a divx installation. However, I follow a general rule of thumb - the less you clutter your computer with software the better. So I'd say just use Media Player Classic Home Cinema, or VLC and avoid any bundle codec installations.
hehe. a 10 year old divx problem. haven't installed that piece o' crap in at least that long. not many others here have either i would venture.
Remove multiple tracks from multiple MKV files
By accoutabc in forum Video ConversionReplies: 3Last Post: 7th Aug 2011, 12:50 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 19:34 -
DirectShow and Drivers--multiple instances of the same capture card
By Austin Covello in forum Newbie / General discussionsReplies: 0Last Post: 7th Feb 2011, 11:43 -
Multiple instances of tmpgenc?
By Bully9 in forum Video ConversionReplies: 1Last Post: 25th Aug 2008, 22:14 -
multiple instances of dshow being activated
By radman202 in forum Newbie / General discussionsReplies: 1Last Post: 29th Jan 2008, 10:50
