lst-Time User. Using an XP Pentium 4 PC, I created a video using Easy CD Creator 5.1 Platinum in Video Impression 1.6. After saving, I exited Video Imp and opened Video CD. After "Record CD Progress" a screen titled "Project Differs from Source" appears reading "One or more files have been modified since creating the project. It is recommended to stop the recording and run Validate Project from the application". The only screen I can find in ECD Creator that's close to this is "Video CD Layout Validation" which reads "No errors detected" for the file I created.
When I try to play on my DVD/TV a message came up "CD is dirty".
I was successful with a temporary workaround by using two PC's as follows:
After creating the file using my XP I saved it to my hard drive and burned it to a CD. Then I copied it to the hard drive of my Windows 98 Pentium 2 PC. Next, I opened ECD Creator Video CD and burned an MPEG CD. I played the CD on my DVD/TV without problem -- 15 minutes (115 images, 7 audio files track, 8 second interval, text on most images). (I have a separate problem of not being able to open Video Impression on this PC).
Since I don't want to have to use two PC's to create a playable video CD, I'm looking for an answer as to why I get "Project Differs from Source" message and how to correct it. It appears that there is something different in XP vs Win 98 in VCD but NO explanation in ECD Creator. I have been unable to get an answer to the question from the software manufacturer. Nothing in the Index or Contents identifies this message. Since the workaround works, I am convinced that there is something unique in XP that's causing the problem.
Any help or suggestion is appreciated -- I'm new at this (in addition to being old!) -- thanks.
Results 1 to 1 of 1
WMV to DVD and problem installing Easy Media Creator 10
By jhayes in forum Video ConversionReplies: 3Last Post: 10th Mar 2008, 15:26 -
Easy DVD Creator by Ether Software
By DW49 in forum Authoring (DVD)Replies: 4Last Post: 30th Dec 2007, 15:33 -
How do I get Roxio Easy Media Creator to Do What I Used to Do With Nero?
By AlleyCatty in forum Authoring (DVD)Replies: 0Last Post: 20th Nov 2007, 16:27 -
Roxio Easy Media Creator 10 verses Pinnacle Studio 11
By snuggels in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2007, 13:10 -
Roxio Launches Easy Media Creator 10
By roxann in forum Latest Video NewsReplies: 0Last Post: 5th Sep 2007, 16:27
