Several years ago I had a stand-alone Sony DVD burner which had a VCR player in it as well. I had made 35 DVDs from material on VCR tape. I no longer have the VCR tapes, or Sony machine. Because the DVDs were made in VR mode and not finalized, they are not viewable in computers or usual DVD players. I need to finalize the DVDs to make them viewable. How can this be done? My goal is to make the DVDs viewable; so if there is some other technique of achieving this besides finalizing the DVDs (such as retrieving the material from the discs and placing it in another media), that is also fine.
Results 1 to 11 of 11
You could try to recover the video with IsoBuster, if you are using XP then also install UDF Reader.
Since posting the thread, I have been reading the threads that were recommended. Several people wrote that they had tried many times with ISObuster and it hadn't helped. One such person wrote that NeroVision was more effective. Any experience with this one?
If as you say they cannot be finalized on a computer, then I don't have much hope of finalizing them. Because when I called Sony tech support, they said only the exact same model standalone Sony machine will finalize them. And I do not know the model number of the machine even.
When you say "restore the video", does that mean "make the DVDs viewable", or extract the data from the DVDs and make it viewable on another medium? -
The only data recovery programs like ISOBuster that I know of are for Windows. I do not know if the license allows installation on more than one PC per user. You should contact ISOBuster support for licensing information.
There is a way to use ISOBuster Free for extracting the video from unfinalized VR mode discs. The video and audio can be extracted from the.tao file and can then be edited and re-authored to make a new DVD. I have done it. The process involves a number of steps. For a basic idea of the process see https://forum.videohelp.com/threads/310357-Unplayable-DVD-because-it-wasn-t-finalized-properly.
Using the paid version of ISOBuster will be likely more convenient than the free version since you have 35 DVDs to recover. However, the free version will let you see what files/tracks the paid version will find, so try that first to see if your video is recoverable. -
I read your link and much related material, and it seems like quite the complex process to use the free version for my work. But still I am confused as to whether to just pay $30 for the product, or to pay an extra 5$ for two years of downloadability, or an extra $15 for the CD. If I just pay $30 for the product, and the system crashes sometime or I need to reinstall the OS, then do I lose the product?
best software to make "fair use" backups of DVDs to DVD +/-R?
By gastrof in forum DVD RippingReplies: 4Last Post: 14th Jun 2011, 15:27 -
How to find out which software created the video CD I made years ago?
By Tjjjc2 in forum Newbie / General discussionsReplies: 4Last Post: 20th Dec 2009, 03:28 -
PANASONIC DMR-E50P I forgot to finalize years ago and now can't play DVD
By JWWILSONMD in forum Authoring (DVD)Replies: 2Last Post: 30th Sep 2009, 19:29 -
can't open mpegs made over 5 years ago - used tmpg
By heidihagen in forum Authoring (VCD/SVCD)Replies: 3Last Post: 20th Mar 2009, 15:40 -
Do hdtv owners use the "fill" mode to get rid of "underscan&
By yoda313 in forum PollsReplies: 20Last Post: 11th Jul 2008, 20:02
