Results 1 to 11 of 11
  1. Hi,
    is there anybody who can help me with video encoding? I want to encode video to MPEG-TS with null packet (PID 0x1fff). Anybody know how to do this? Is it possible?
    My current command:
    ffmpeg -i audio.mp2 -i video.mpg -s 720x576 -minrate 3200k -maxrate 3200k -bufsize 3200k -vcodec libx264 -vpre libx264-iptv -acodec copy -r 25 -f mpegts out.mpg
    Sep 2007
    Europe
    mpg isn't a transport stream container. You should use out.ts
    About null packets...
    AFAIK, there is no setting for that but I once looked in the FFmpeg source code where null packets are mentioned so I suppose they are inserted automatically (not sure).
    I would say, just try and see if the clip is accepted.
  3. Thanks for fast reply . How can I check it? Is there any app to check null packets in file?
  4. do not know about ffmpeg, but x264/h264 encoder and tsmuxer should serve your purpose.
    installing all invidual libraries gives better results, follow distro-documentation.
  5. Thank you Bonie. Now it looks better , but I have another problem. I want to mux two files: video.h264 (720x576, 25fps, 2.5Mbps CBR) and audio.mp2 (192kbps, 48kHZ) to MPEGTS 3.2Mbps CBR.
    Mediainfo information from out.ts file muxed with tsMuxeR:
    Overall bit rate : 3 200 Kbps
    Maximum Overall bit rate : 35.5 Mbps
    I need to mux it with CBR. Second thing is NIT table. I want to set only PAT and PMT nothing else.
    Please help.
  6. @adismsc
    i do not have much experience or deep knowledge about DVB - Transport stream.
    i do not think that any free encoder or muxer will serve your purpose for NIT Table. PAT and PMT.
    Search for NTT HVE9100 H.264 and MPEG-2 Broadcast Encoder.
    Last Q?
    does ffmpeg serve your purpose for NIT Table. PAT and PMT?
    coz they have specific broadcast version too!!!
  7. My specification is listed below:
    Elementary stream bitrate [kbit/s]
    video: 2575
    audio: 2 x 192
    subtitle: -
    PAT/PMT: -
    Stuffing: -
    Component TS bitrate [kbit/s]
    video: 2652
    audio: 395
    subtitle: 45
    PAT/PMT: 45
    Stuffing: 62
    Total: 3200
    Additional required components:
    PAT
    PMT
    Null packets
    without others:
    NIT, SDT, EIT, etc.
    I have two files: video.h264 (720x576, 25fps, 2.5Mbps CBR) and audio.mp2 (192kbps, 48kHZ). How can I mux it with this spec? Can I?
  8. OpenCaster http://www.avalpa.com/the-key-values/15-free-software/33-opencaster
    AFAIR TS in FFMPEG is not very well implemented (some people says that it is broken)
  9. No I have another problem
    This is how my current script looks like:
    vcodec="h264"
    acodec="mpga"
    bitrate="2500"
    arate="192"
    samplerate=48000
    ext="mpg"
    mux="ts"
    vlc="/usr/bin/vlc"
    fmt="mpg"
    dst="/home/adam/test/"
    for a in *$fmt; do
    $vlc -I dummy -vvv "/home/adam/test/" --sout "#transcode{vcodec=$vcodec,venc=x264{profile=main,level=3.0,hrd=cbr,bframes=2},vb=$bitrate,acodec=$acodec,ab=$arate,samplerate=$samplerate,channels=2}:standard{mux=$mux,dst=\"$dst$a.$ext\",ac$
    done
    After encoding with the above script everything seems to be ok (for both video and audio bitrate codec is constant) apart from two things: Bitrate of the container should also remain CBR but this is not the case. Also, stuffing component (0x1 ffff) - null packet is missing. Is it possible for you to correct the script to make null packet as well as bitrate of the container constant (3,2 Mbps CBR) ?
  10. try to play with -muxrate if You insist to use ffmpeg
  11. I tried, but without the expected results (CBR).
