This inquiry is a continuation of my journey in seeking alternatives to Premier Pro especially in the areas of downsizing from HDV footage and encoding.
1) Upfront: in your considered view and from you own personal experience, assuming very similiar settings, does HC encoder yield better output after encoding SD NTSC 16 9 ( presumably BFF + interlaced) files as directly compared to Premiere Pro?
2) Would I obtain more quality if I feed HC Enc a customized/optimized Avisynth file as opposed to just opening an. avi file?
3) What happened(s) to the audio component as I input a file with audio?
4) Specifically: As far as settings goes, please I value your sage advice, what should I be picking here:
Main tab:
a) Is it acceptable/recommended to selcet dc 9 or 10 over 8? What's "right"?
b) Interlaced: yes or no?
Settings I tab:
a) Interlacing: what choice is most suitable?
b) Same goes for chroma downsampling!
c) Is quality (in regards to definition/clarity and sharpness) lost if I choose progressive over interlaced?
Settings III tab:
a) Must chroma output be 4:2:0/YV12 since the end delivery is MPEG-2 spec on dvd?
What are your thoughts in chosing FOX 1 as the go to matrix? Should something else be picked?
Really appreciate your help.
Thank you
Results 1 to 1 of 1
Optimizing Settings for youtube upload like fast start etc for x264 encoder
By vibes992000 in forum Video Streaming DownloadingReplies: 2Last Post: 5th Feb 2012, 23:30 -
kmttg +encoder settings
By Danneauxsvh in forum Video ConversionReplies: 2Last Post: 4th Jan 2011, 15:38 -
Attn: All Premiere Pro experts!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 1st Sep 2010, 03:30 -
hc encoder profile settings
By bmwracer in forum Video ConversionReplies: 12Last Post: 28th Feb 2008, 16:46 -
change dimensions easily, and encoder settings?
By ChillBill in forum EditingReplies: 3Last Post: 12th Aug 2007, 13:49
