Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
Results 1 to 13 of 13
    Oct 2008
    Russian Federation
    How to convert frame rate in Linux? For example, convert 50 fps progressive to 25 fps interlaced? In Windows it is very simply by using AVISynth's function SelectEvery, but what about Linux? Using ffmpeg or something like this? And is it possible to double frame rate using motion vectors like MVAnalyse/MVFlowFPS do?
  2. AviSynth works in Wine. The AviSynth script to convert 50p to 25i is:
    SeparateFields()
    SelectEvery(4,0,3)
    Weave()
    AviDemux is available for Linux. I don't know if it will do what you want though.
    Oct 2008
    Russian Federation
    jagabo, pity I tried a lot of things to make AVISynth work under wine but failed to. Probably the main problem is not in AVISynth but in codecs since it always fail to load AC3ACM for example, but DirectShowShource doesn't work at all... so I wasn't able even to try plugins...
    Anyway, I suppose wine is not a fastest way, native Linux would be better...
  4. ac3acm is vfw based and directshowsource is directshow based of course - those are system dependent on windows installed codecs/splitters
    ffms2 apparently works fine with wine
    Oct 2008
    Russian Federation
    poisondeathray looks like ffms2 really works, thanks. Well, i still haven't got audio but maybe I'll find a way...
    BTW, what is faster to convert video to MPEG2 - Wine*HCEnc or AVIDemux + Wine*AVSProxy?
  6. you can use avisynth in linux to with avs2yuv.
    how to use it? search your distro-forum or on the net.
  7. Originally Posted by lovyagin View Post
    did you specify audio in the script ? e.g. ffaudiosource() with audiodub()
    Not sure about speed with those on linux, you can do some short tests. But I'm certain hcenc's quality will be better.
    Oct 2008
    Russian Federation
    I tried ffmpegsource2 and specify atrack=... but can't know track number. Anyway I tried several and they doesn't work saying nothing or "not an audio track" or "no audio data" (I tried in virtualdub).
    Suppose so too...
  9. Originally Posted by lovyagin View Post
    usually atrack =-1 , or you can use ffaudiosource and ffvideosource with audiodub
    What kind of file? where is it from? post mediainfo view=>text back here
    Oct 2008
    Russian Federation
    Format                           : AVI
    Format/Info                      : Audio Video Interleave
    File size                        : 835 MiB
    Video
    Format                           : MPEG-4 Visual
    Format profile                   : Advanced Simple@L5
    Format settings, BVOP            : No
    Format settings, QPel            : No
    Format settings, GMC             : No warppoints
    Format settings, Matrix          : Default (H.263)
    Codec ID                         : XVID
    Codec ID/Hint                    : XviD
    Duration                         : 58mn 14s
    Bit rate                         : 1 806 Kbps
    Width                            : 704 pixels
    Height                           : 400 pixels
    Display aspect ratio             : 16:9
    Frame rate                       : 25.000 fps
    Color space                      : YUV
    Chroma subsampling               : 4:2:0
    Bit depth                        : 8 bits
    Scan type                        : Progressive
    Bits/(Pixel*Frame)               : 0.257
    Stream size                      : 752 MiB (90%)
    Writing library                  : XviD 1.2.1 (UTC 2008-12-04)
    Audio
    Format                           : MPEG Audio
    Format version                   : Version 1
    Format profile                   : Layer 3
    Codec ID                         : 55
    Codec ID/Hint                    : MP3
    Duration                         : 58mn 14s
    Bit rate mode                    : Constant
    Bit rate                         : 192 Kbps
    Channel(s)                       : 2 channels
    Sampling rate                    : 44.1 KHz
    Stream size                      : 80.0 MiB (10%)
    Alignment                        : Split accross interleaves
    Interleave, duration             : 80 ms (2.00 video frames)
    with atrack=-1 virtualdub returns
    AVISynth open failure:
    FFAudioSource: no audio track found
    (no video either in this case), atrack=-2 returns video without audio as it should, atrack=0 says "not an audio track", atrack=1 fails with "audio track contains no audio frames", and atrack=2 says "out of bounds track index selected". The clip is fully playable by SMPlayer video+audio though.
    UPD: I tried second clip (second part from same source) and it works perfectly. So something wrong with clip indeed. But it is playable
  11. Originally Posted by lovyagin View Post
    Sometimes when a video is cut improperly, this happens
    You can try divfix++ to repair (I think windows only)
    Or you can demux audio (e.g. with ffmpeg ) & load separately in the script
    Oct 2008
    Russian Federation
    Yup, I'll try somehow, probably demuxing, or maybe BASSAudio or something like this will work. Thank you a lot for helping!!!
  13. Originally Posted by lovyagin View Post
    Not sure if bassaudiosource will work, because it uses dyamically linked .dlls which were compiled for windows, but you can try it
    Once it's been demuxed , ffaudiosource should work
    To stream copy audio e.g.
    ffmpeg -i input.avi -vn -acodec copy output.mp3
    Then use ffaudiosource on the mp3
