I have a big ( 800mb ) AVI file, need to remove boring episode in the middle of my movie. How can I do it using freeware application ?
Results 1 to 17 of 17
You can also use solveigmm avi trimmer and virtualdub to cut lossless.
Using VirtualDub:
1) File -> Open Video File
2) Video -> Direct Stream Copy
3) Mark-in*, mark-out**, Edit -> Cut, repeat if you want to cut more than one section.
4) File -> Save as AVI.
Note that in Direct Stream Copy mode VirtualDub will only cut on keyframes (marked with a [K] in the status line). If you want frame accurate cutting you have to use Smart Rendering and Full Processing mode, and you have to set up the compression codec to match your source.
* Mark-in = Edit -> Set Selection Start
** Mark-out = Edit -> Set Selection EndLast edited by jagabo; 7th Nov 2011 at 07:32.
and about this - https://forum.videohelp.com/threads/340553-make-new-file-form-selection?p=2118890#post2118890
how can I make new file form selected episode ? -
VirtualDub - amazing & easy-to-use application, thanks for that.
But sound become terrible. -
Virtualdub doesn't change the sound, assuming you had audio (at the top) set to "direct stream copy"
What do you mean by "terrible"? -
like loud "SH-SH-SH!"
ps.
looking for some "manual avi splitter" aplication -
ok, I found famous "avi splitter classik", but look like this application have no updates since 2005 !
use another recomended software "avidemux_2.5_r7200_win32.exe"
problem with sound again.
maybe it is because of "vbr audio" ?
Deleting chapters in the middle of each title (episode)
By videobruce in forum Authoring (DVD)Replies: 20Last Post: 20th Dec 2010, 17:13 -
how to get rid of text in the middle or a avi video file?
By nsctsunomi in forum EditingReplies: 7Last Post: 22nd Nov 2010, 11:47 -
Philips DVP3982-37 AVI playback stops in middle
By BKN6006 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 27th Mar 2010, 16:43 -
800mb avi; Would want it to go onto a 700mb CD
By mark63534 in forum Newbie / General discussionsReplies: 39Last Post: 28th Feb 2010, 20:31 -
Burn A dvd from AVI. and stuck in the middle
By jtish in forum DVD & Blu-ray WritersReplies: 15Last Post: 5th Jan 2008, 17:43
