Hello,
I am rather new and I have a small problem.
I made a backup of a blu-ray with DVDFAB. It worked very well. I only want to put the subtitle in the MKV file. I have extracted the subtitle with HDRstreamextractor and converted it to idx/sub. I tried putting it in the MKV with MKV merge. The subtitle is displayed when I open it with mediainfo, but will not pisplay in my mediaplayer. I also tried .srt and it has the same problem.
Can someone give me the correct procedure or settings for MKV merge for muxing in the subtitle.
Thank you.
ANd you are sure that your media player supports mkv with embedded subtitles?
And be sure to disable header compression in mkvmergegui ( File->Options->Disable header compression) when you make a new mkv. -
Thanks for the reply.
I found the problem. The .srt file wasn't sorted correctly. I made a new srt file and this solved my problem. Just to be sure I disabled the headr compression.
Thank you. I was struggeling for a few days allready
Converting to MKV plus adding diff Audio & Subtitle tracks
By evile1690 in forum Video ConversionReplies: 3Last Post: 5th May 2010, 01:37 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 09:42 -
Problem with adding subtitle to a TV Series DVD
By hellbound in forum SubtitleReplies: 3Last Post: 2nd Sep 2009, 16:56 -
Any idea about this problem ( adding subtitle to a Dvd )
By khatab1 in forum SubtitleReplies: 4Last Post: 15th Sep 2008, 12:05 -
DVD Flick Problem adding subtitle
By MindF in forum SubtitleReplies: 1Last Post: 2nd Apr 2008, 12:49
