Here's the problem:
I want to install win7 (64bits) on an old hdd which contain a Xp partition (i don't want to loose it).This partition takes all the hdd space indeed (about 180gb) so i thought perhaps a good tool would allow me to schrink the size of this partition (to about 160gb would be enough) in order to have some unallocated space.
Other problem the xp partition contain windows files but doesn't boot anymore for some reason, and i use another hdd since like 6 months now. I can see that as a problem if i want to boot on the win7 unless somehow i displace it and the win7 partition becomes the 1st partition ? Enlighten me please
Ive read (on wikipedia) Norton Partition Magic can do all that altough it's not sold anymore. Anyone tried this soft and operations successfully before ? How safe is it ?
Thanks for your inputs
*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
Try Gnome Partition Editor > GParted via bootable iso / usb ... iso is 110mbs.
As the drive is questionable Id backup the data by trying macurium reflects boot cd before making partition changes ... if it errors during the imaging of the drive then its a question of risk ... if the data is valuable then install win 7 on another drive instead. -
I believe my question was more about Norton partition magic and its capabilities, wasn't it ? Thank you anyways
If your system is 64 bit Norton partition magic won't work in it.
It was ... but you should not use that old version to setup partitions or make modifications when it comes to window 7 setup ... it has bugs that can royally screw up a new windows 7 install
Bjs gave yo sound advice, why would you want o use date software on a new install, especially when you have expressed concern over about your XP data. The two apps bjs mentioned are what i use to set up dual boots on systems that have a previous OS installed. The software is very easy to use and they're many guides on line. AIf you uncomfortable using Linux products you can try Paragon Partition Manager its windows based but the previous mentioned software are much better imo.
Murphy's law taught me everything I know. -
Like you said. It was acquired from PowerQuest by Symantec and promply discontinued in favor of Symantec's less capable program Ghost.
GParted is free and does much the same. Put it on a self booting Linux disc. Like the old Partition Magic, it will re-size a Windows partition without refomat which would delete the files. Backup first just in case. I've never had a problem with GParted.
PS: I'd bet an old version of NPM would be limited to 4GB or 8GB hard drives. It is that old.Last edited by edDV; 7th Nov 2011 at 18:02.
http://www.kiva.org/about
Looking for free software to partition and backup netbook partition
By jimdagys in forum ComputerReplies: 4Last Post: 30th Nov 2011, 22:20 -
Question about Disaster after using Partition Magic
By jimdagys in forum ComputerReplies: 9Last Post: 20th Nov 2009, 12:22 -
Merging partion Hard Drives
By pantangs in forum ComputerReplies: 2Last Post: 24th Jul 2009, 17:11 -
Best way to partion a 1TB into 2 partitions using Fat32
By cal_tony in forum ComputerReplies: 6Last Post: 21st May 2009, 13:10 -
Partition Size Issues for New PC with Win98
By bevills1 in forum ComputerReplies: 21Last Post: 9th Aug 2008, 09:13
