I have used software "sub2divx332" to add subtitles in avi as softsub and in my DVD player i had no problem.
BUT if i want to see it in my laptop with MPC subtitles does not display.
At the option "Play", "subtitles" is grayed out.
In the icons area (right lower near clock) shows only ffdshow audio icon
I have Windows 7 64bit
codec: cccp with MPC Home Cinema 1.5.3.3514
Any suggestions? I want to see the subs (size,font etc) before i transfer it to my DVD player
Thanks in advanced
The official divx player should support such subtitles, http://www.divx.com/en/software/divx-plus/player
You could also try VLC, kmplayer, potplayer, smplayer. -
I'll try Divx player although i prefer to have only one and for years i am using MPC.
I hope the solution is something in the settings in MPC.
Anyone else?
MPC won't display on secondary monitor
By Monarch1st in forum Software PlayingReplies: 2Last Post: 17th Feb 2012, 12:11 -
How to get MPC to display images?
By SignedupGuest in forum Newbie / General discussionsReplies: 2Last Post: 4th Oct 2010, 14:31 -
wmp11 & mpc-hc display audio info on the screen for mpg,avi files
By Danneauxsvh in forum Software PlayingReplies: 4Last Post: 6th Jun 2010, 12:16 -
MPC:HC disabling G15 LCD display?
By XenonLite in forum Software PlayingReplies: 5Last Post: 9th Dec 2008, 04:38 -
Softsub mkv ----> hardsub avi?
By Silvertroy in forum Video ConversionReplies: 2Last Post: 1st Jun 2008, 11:14
