Hi all,
This is my first post here, and I think it's the right place for such question.
The subject explains what I want to do by itself.
My final goal is to create a Video File with the Video from an HD FLV Source and the Audio from this file (dubbed).
I tried several apps to do the task because my knowledge is kind of limited about the process.
All the tries resulted in MP3 files with a mild wheezing not present (or not so perceptible) in the original RM File.
I thought it could be problem of excessive decibels and, using MP3Gain I figured out the files was with 98 dB. I lowered it to "normal" (89 dB) and the wheezing decreased, but I still can hear it.
Maybe something in the conversion RM ---> MP3 screwed up, I don't know...
[OFFTOPIC]
Who should I talk with to fix a nickname mistake. In my last name, there is mistyped uppercased 'U'.
If I exported correctly, here is the requested data:
Code:General Complete name : C:\Users\Usuário\Desktop\Vid1.rm Format : RealMedia File size : 60.4 MiB Duration : 19mn 46s Overall bit rate : 413 Kbps Video ID : 1 Format : RealVideo 4 Codec ID : RV40 Codec ID/Info : Based on AVC (H.264), Real Player 9 Duration : 19mn 46s Bit rate : 349 Kbps Width : 640 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate : 23.976 fps Bits/(Pixel*Frame) : 0.047 Stream size : 49.4 MiB (82%) Audio ID : 0 Format : Cooker Codec ID : cook Codec ID/Info : Based on G.722.1, Real Player 6 Duration : 19mn 47s Bit rate : 64.1 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Bit depth : 16 bits Stream size : 9.07 MiB (15%)
I used to have a utility, that I can't remember the name of at the moment, that 'extracted' (probably converted) the audio in an .rm to .wav... if I remember correctly. I'll see if I can find it again. Don't ffmpeg and mencoder both have support for the older Real codecs, though?
Edit: Websearches have turned up what I think is a console (CLI) utility, ra2wav (although that's not what I remember using). You might also be able to use Tinra to convert the video and extract the video from the converted version, but I'm not sure you won't run into issues with that - like FLV, Real formats tend to be somewhat highly compressed, so the audio and video quality often suffer - and converting to other formats afterward may not help.
If cameras add ten pounds, why would people want to eat them? -
Well, in one of my tries, I stumbled upon Pazera Free Audio Extractor. With this program I found an option under Output Format called Try extract original audio stream.
The result file was a WAV File fo 199 MB.
However, I have two questions about the process:
- The program has several files, but only TWO executables: The main program (GUI) and ffmpeg.exe.
With this, I'm supposing it uses ffmpeg to do the task, just like Ai Haibara said.
What is the command line to the this task without the GUI? - The source RM Video File has near of 60 MB. Why the result audio file is more than 3x large?
[EDIT]
Well, everytime we we're happy with something working well, something else comes to screw up.
Honestly, I should be warned about this...
Anyway... The dubbed audio was extracted, but if compared to HD Video, it's not synchronized. Is there any way to change audio speed using something from Video Source?
I don't know, retrieve some information about original audio (english) and then apply it to dubbed audio, increasing or lowering its speed, in order to synchronize automatically?Last edited by Bruno AUgusto; 12th Nov 2011 at 09:38. Reason: Provide Additional Informations
And how exactly this feature would work? I was thinking something less manual, like input the correct video, the wrong audio and something "mathemagically" help to fix.
URGENT is everything someone INCOMPETENT did not ON TIME and want you KILL yourself to do in RECORD time.
How to Extract /Convert RMVB Audio Files to MP3 or WAV?
By devilcoelhodog in forum AudioReplies: 6Last Post: 28th Dec 2011, 10:07 -
Easy way to extract audio (DTS) from a .m2ts stream and convert it to AC3?
By marklight in forum AudioReplies: 1Last Post: 8th Sep 2008, 17:42 -
.Mkv file: Extract, convert, and add suctitle to DVD?
By Super Warrior in forum SubtitleReplies: 2Last Post: 11th Dec 2007, 18:47 -
Extract part of an audio file into a new file without rencoding?
By therock003 in forum AudioReplies: 4Last Post: 19th Oct 2007, 16:32 -
What software should I use to extract DVD audio and convert it to mp3s?
By maccaneer in forum MacReplies: 2Last Post: 4th Sep 2007, 18:03
