Same mouse as I used with previous versions of Vegas. It used to be that when I rolled the wheel, the timeline would zoom in and out perfectly. Now, with version 11, I have to roll the wheel pretty far before it even zooms a little, and then the zoom isn't smooth, it jumps.. Anyone experience this?
Results 1 to 10 of 10
umm. no, it works just like v6-v10 here.
Use the up and down arrows, much faster and precise.
Anyway, the mouse is a Windows function, not Vegas.
I know your question is about the mouse, but did you know you can get a Vegas keyboard? I have one and it's great for splitting and zooming. Gives your left hand something to do.
[Attachment 9476 - Click to enlarge]Last edited by budwzr; 5th Nov 2011 at 20:34.
I'm not hardcore enough to get a special keyboard for editing =) Though I would like to fix this mouse issue!
You might try the control panel mouse settings and see if you can adjust it. Could the wheel be gunked up? Does the older version of Vegas still work OK?
Maybe your mouse and/or driver is too old. Maybe the battery is low and the signal is too weak.
Maybe your computer is too slow for the new software. -
I saw that you succeeded, but I don't find it unfortunately where it is possible to fix it.
Anyway thank you very much that you trying to help. : )
Vegas: Timeline pictures?
By duderdude2 in forum EditingReplies: 4Last Post: 18th Feb 2010, 20:22 -
Sony Vegas: Timeline Cropping
By mltwitz in forum EditingReplies: 9Last Post: 29th Aug 2009, 05:16 -
Mouse Wheel
By LabanB in forum ComputerReplies: 2Last Post: 31st Dec 2008, 19:17 -
pan and zoom in vegas 8
By wingfan in forum EditingReplies: 4Last Post: 4th Oct 2008, 10:53 -
Timeline in Vegas 8?
By guzzi in forum Newbie / General discussionsReplies: 3Last Post: 29th Jul 2008, 19:48
