I plan to use BD Rebuilder for this unless there's something better? I want the least compression possible and just the movie. I don't want any audio compressed AT ALL, how do I do this? I have never really used BD Rebuilder or I have, but just don't remember how.
Also if the movie is in 3D? How do I make sure I'm handling the 3D version of it? I mounted one of my rips of a 3D movie onto my computer and it only played the 2D version - or maybe I was playing the wrong file.
Anyway...
I need to
1. Encode a BD50 movie to a 25GB disc
2. Least compression possible, only using the movie itself
3. All audio codecs included, original bitrates
Any help on how to do this would be great.
Results 1 to 10 of 10
In BD Rebuilder, set Mode to Movie Only Backup.
In Settings-->Output Options select Target Size BD25
In Settings-->Setup, put a check mark in the box next to Keep HD Audio for BD 25 encoding. Also put a check mark in the settings to not reencode DTS to AC3 for BD 25. If you want all the audio streams kept intact, you can select all of them once you import the movie into BD Rebuilder. Keeping all the audio streams takes up a bit of room that could be used for the video however.
To work with 3D backups, I believe you'll have to use DVDFab. -
I see more options telling to Remove workfiles and output folder after rebuild and burn...can I select these?
What about the "keep only BDMV/CERTIFICATE folders" option?
Is x264 encoder correct? or should there be a different one?
There are encoder settings - which is the BEST quality for BD-25? is it the High-speed option (BD-25)?
One pass encoding should be CRF or ABR encoding?
I'm just trying to be thorough -
x264 and i would go with CRF. Beware that 7.1 HD audio could easily consume +4gb of space, i would down convert to 5.1.
Murphy's law taught me everything I know. -
Since your using BD25's check the High Speed BD25 option under Settings-Encode Settings,it will cut your encode times in half.
It's been a while since i used bd rebuilder switch to backing up to a media PC, but thats is my understanding is it down mixes multi channel 7.1 and 5.1 e-ac3, etc to 640 5.1 ac3. If it were a disk with DTS 5.1 i would probably leave audio intact if you have a DTS capable system.
How to shrink 3D BD50 to BD25
By danswano in forum Authoring (Blu-ray)Replies: 20Last Post: 23rd Oct 2013, 08:19 -
BD50 to BD25 and keep menus
By Eyecan'tcode in forum Blu-ray RippingReplies: 1Last Post: 24th Dec 2011, 19:26 -
BD50 to BD25 How they can do this and What is the quality??
By winter snake in forum Blu-ray RippingReplies: 5Last Post: 13th Oct 2010, 15:50 -
bd50 t0 bd25 from another region?
By tomrip in forum Blu-ray RippingReplies: 5Last Post: 16th Oct 2009, 15:41 -
Shrink BD50 to BD25
By mis3 in forum Blu-ray RippingReplies: 2Last Post: 5th Mar 2009, 07:54
