How to build Hybrid Fontend Debian installer package?
Hope, it is using raw-codec libraries as well like libmp3, libaac, libaften, libxvid and libx264 as well.
I try to build from tar ball from Arch Linux repo without instructions but no success.
Details from Hybrid Website:
Hybrid
Hybrid is a multi platform (Linux/Mac OS X/Windows) Qt based frontend for a bunch of other tools which can convert nearly every input to x264/Xvid/VP8 + ac3/ogg/mp3/aac/flac inside an avi/mp4/m2ts/mkv/webm container, a Blu-ray or an AVCHD structure.
Here's a general feature list:
Hope this good tool will be maintained un-biased fairly good in all future releases with all detailed configuration encoding support for raw-codec libraries as well like libmp3, libaac, libaften, libxvid and libx264.
- Extensive ability to configure x264s setting (with dependency checks)
- tagging support for mkv/mp4
- chapter support for mkv/mp4/Blu-ray
- subtitle suppot for mkv/mp4/Blu-ray
- separated audio-, video-, filter profiles
- an integrated bitrate calculator
- accepts vc-1 and avc raw input
- manual&automatic creation&passthrough of chapters
- ability to encode single title/chapters
- a job-control
- aac/mp3/ac3/ogg/flac audio encoding with neroAacEnc/mencoder/ffmpeg
- filtering through mencoder (+ some resize automation)
- acceptable Input: avs and everything that mplayer/ffmpeg can decode
- supported video output formats: MPEG-4 ASP (Xvid), MPEG-4 AVC (x264, cuda), VP8 (vpxenc)
- supported audio output formats: ac3, ogg vorbis, mp3, aac, flac
- supported containers: avi/mp4/mkv/m2ts, Blu-ray or a AVCHD structure
- audio/video passthrough -> can be used for muxing, tagging, chapter editing
update:-
i just dipped it under WiNe. and it all goes smooth and FiNE!
Pls, discard this thread.
Results 1 to 1 of 1
What is windows installer for?
By jyeh74 in forum Newbie / General discussionsReplies: 4Last Post: 7th Jan 2010, 14:51 -
windows installer?
By marcusden69 in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 15th Feb 2009, 08:36 -
Trouble with avidemux and [url]www.debian-multimedia.org[/url]
By Verlager in forum LinuxReplies: 24Last Post: 1st Dec 2008, 23:27 -
Converting video of any format to MOV or MP4 Linux/Debian
By lordshadow in forum Newbie / General discussionsReplies: 11Last Post: 31st Aug 2008, 11:35 -
dvd to psp fails on debian with ffmpeg can someone see what I'm doing wrong
By oswaldkelso in forum ffmpegX general discussionReplies: 0Last Post: 26th Jul 2007, 08:57
