  1. I'm burning a Blu-ray for the first time using a Apple ProRes 422, 1920x1080 Quicktime, frame rate 24p. Using Toast Titanium 11, 'Best Quality' setting. When I play back on a Blu-ray player, the image looks great but the audio is out of sync. When I play the same Blu-ray on a Play Station 3, the audio is in sync, but the picture stutters.
    Is my 'Best Quality' setting causing this? Should I go back down to 'Better Quality', which is the factory default? Or, on he other hand, should I be doing a Quicktime Conversion at of Final Cut Pro to change the Quicktime frame rate to 30fps or 29.97 fps? Or is there something else I may be missing in problem-solving this?
    Thanks, in advance, for your advice.
    Oct 2005
    666th portal
    1080 24p is in the blu-ray spec. that shouldn't be a problem. it's whatever toast is doing to the re-encode to blu-ray spec video that's the problem.
  3. So any suggestions to what I should do at this point in terms of changing Toast settings, etc.?
    Oct 2005
    666th portal
    hang in there maybe a mac user will chime in.
    canada
    Thread moved to the mac forum where you can get more responses.
  6. Does the prores version play fine?
