I've tried to download the binary from the ffmpegx website, but all I get is stuff like this:
Êþº¾Êþº¾1 PVèþíúÎ
Am I doing something wrong? I have a G5 iMac running Panther.
Command-click the link (or right-click on the link, if you have a mouse or trackpad with more than one button, and select your browser's equivalent of "Save Link As".)
If cameras add ten pounds, why would people want to eat them? -
It doesn't matter. The installer is smart enough to take care of that.
It means something went wrong with the installation of the binaries. At application launch, the binaries are checked for validity. The binary noted in red is not good. That binary should be installed again. Do verify the size of the binary (a relatively easy check):
mpeg2enc.intel 501,480 bytes
mencoder 16,655,780 bytes
mplayer 15,869,784 bytes
If the installer lists mencoder and mplayer in red, then please verify that you pointed the installer to the unzipped files.
If the installer lists mpeg2enc in red, then give this copy a try. Unzip before use.
The installer will overwrite the invalid file with the new file.
mpeg2enc.
By zaque2004 in forum ffmpegX general discussionReplies: 49Last Post: 4th May 2014, 04:02 -
Problem opening mpeg2enc binary
By itegil in forum ffmpegX general discussionReplies: 2Last Post: 6th Aug 2010, 22:48 -
Problem converting VOB to MPEG2 with mpeg2enc
By Massa in forum ffmpegX general discussionReplies: 3Last Post: 3rd Jan 2009, 06:51 -
ffmpegX mpeg2enc compiling problem
By dubis in forum MacReplies: 5Last Post: 12th Sep 2008, 16:54 -
Problem with mpeg2enc binary
By lkearl in forum ffmpegX general discussionReplies: 1Last Post: 11th Aug 2007, 03:47
