    Aug 2006
    Just wondering, what's the best method for exporting work in FCP? Currently, I select export/quicktime. Then I select 'current settings' and 'make movie self-contained.' My goal is to end up with the best possible video which I can then convert to any number of formats as needed. I'm confused if this is the best method, or if I should be selecting quicktime conversion.
    Thanks in advance!
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Originally Posted by Jeff_NJ View Post
    ...My goal is to end up with the best possible video which I can then convert to any number of formats as needed.
    I'd archive it as ProRes422 (or AIC).
    http://www.kiva.org/about
