mkv plays on pc noton my lg350 used mkvmerge which usually works but not this time anyone any ideas
	Disabled header compression? In Mkvmergegui under File->Options and select "Disable header compression..." and then make a new mkv.
 And I changed your thread title.
	Welcome to the forums. Install MediaInfo and post the results here from your file. My guess is that your file contains stripped headers. I'm not sure if any BluRay/DVD/media players support that. We've been getting a lot of posts about it causing problems. It seems to be like GMC was in Divx a few years ago where any file that had it was going to be difficult to play. If your file does have stripped headers you'll have to research a way to fix that. A few of our members know what to do about it but as I've never seen it I don't remember what it takes to fix it.
	Unique ID : 241184912822781011955634377689880831587 (0xB572864A7B009399B0DE7F20FAB3A663)
 Complete name
 Format : Matroska
 Format version : Version 2
 File size : 6.56 GiB
 Duration : 2h 10mn
 Overall bit rate : 7 197 Kbps
 Encoded date : UTC 2011-10-26 03:46:55
 Writing application : mkvmerge v4.8.0 ('I Got The...') built on May 24 2011 03:12:58
 Writing library : libebml v1.2.0 + libmatroska v1.1.0
	General
 Complete name :
 Format : Matroska
 Duration : 2h 10mn
 Video
 Format : AVC
 Format profile : High@L4.1
 Format settings, CABAC : Yes
 Format settings, ReFrames : 5 frames
 Muxing mode : Header stripping
 Codec ID : V_MPEG4/ISO/AVC
 Duration : 2h 10mn
 Bit rate : 5 689 Kbps
 Width : 1 280 pixels
 Height : 528 pixels
 Display aspect ratio : 2.40:1
 Frame rate : 23.976 fps
 Color space : YUV
 Chroma subsampling : 4:2:0
 Bit depth : 8 bits
 Scan type : Progressive
 Bits/(Pixel*Frame) : 0.351
 Stream size : 5.05 GiB (77%)
 Writing library : x264 core 119 r2106 07efeb4
 Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=5689 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
 Language : English
 Audio
 Format : DTS
 Format/Info : Digital Theater Systems
 Codec ID : A_DTS
 Duration : 2h 10mn
 Bit rate mode : Constant
 Bit rate : 1 510 Kbps
 Channel(s) : 6 channels
 Channel positions : Front: L C R, Side: L R, LFE
 Sampling rate : 48.0 KHz
 Bit depth : 24 bits
 Compression mode : Lossy
 Stream size : 1.38 GiB (21%)
 Language : English
	Stripped headers is why it won't play on the LG. Either do a search for information on how to fix it or wait and see if someone tells you how to fix it here.
	I have already told how to do that. Stripped headers = header compression.
 You can also check so it actually does it, open mkv, click on the video/audio track, under extra options be sure the compression is set to none. Start muxing. Open the mkv with mediainfo and check what it says under muxing mode. It should not say header stripping.
  MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-rayBy Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19
  How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 03:45
  Problems Concerning able to play mkv on TVBy whatismagnet in forum Newbie / General discussionsReplies: 1Last Post: 28th Dec 2011, 04:26
  MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVRBy dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 06:15
  Can't play mkvBy quanz in forum Software PlayingReplies: 12Last Post: 8th Oct 2009, 17:01
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
