I have a gateway mx3560 and just reformatted it.
It is running windows xp SP3
I have a NTSC format DVD which windows cant even read. (Thinks its a blank)
All other dvd functions are normal.
When I insert the dvd into my dell inspiron 1525 running windows 7, it works fine.
Any idea whats going on?
DVDR/W media? Some dvd-rom/writers might not read all dvdrw media.
(It has nothing to do with it's beeing NTSC.) -
it seems to read it fine with just about anything else, any NTSC disk I put in shows up as blank
Sounds to me like somehow you've managed to reinstall XP and completely destroyed its ability to read any UDF format discs. Install the free UDF Reader from our Tools section and I bet it will fix your problem.
DVD+r shows up as blank disc
By garylanders in forum MediaReplies: 9Last Post: 25th Nov 2011, 06:22 -
Help...Blank DVD-R disc shows region 8...
By Praetorian_Prefect in forum Newbie / General discussionsReplies: 9Last Post: 24th Jun 2011, 00:17 -
PGCEdit shows blank previews
By thief_ in forum DVD RippingReplies: 3Last Post: 3rd Jun 2008, 06:54 -
MpegStreamClip shows blank screen/needs update?
By jwnulife in forum Newbie / General discussionsReplies: 3Last Post: 19th Dec 2007, 10:42 -
LCD Projector Shows a DVD as Blank When Using Windows Media Player 10
By jetset in forum Newbie / General discussionsReplies: 7Last Post: 31st Aug 2007, 16:44
