  1. Hi guys!i'm using handbrake for dvd ripping,it produces better results only for single movie dvd 5.But i have dvd 5 with 4 or 5 old movies(like casablanca,wonderful life) compressed in it.These movies appear blocky only in some points.while using handbrake for converting these videos deblocking,increasing bit rate none of them works.so please provide me best way of ripping these movies....thanks in advance
    Jul 2001
    Garbage in, garbage out. Can't make silk from a sow's ear.... I can go on but I think you get the idea.
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    These movies have already been completely ruined by jamming all of them onto one DVD....now you want to ruin them some more? These aren't ZIP files man.....once the quality is gone it is gone for good.
    Also you are not "ripping" them....you are converting them.
  4. These movies have
    for good.
    them.
    I thought this website is full of video geeks who can solve or just try to solve any questions.so i joined in.i never expected such a idiotic reply for my first post.i would never visit this site again....logging out
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    We are all out of magic wands.
    Dec 2005
    Pocatello, ID
    These movies have
    for good.
    them.
    Wow, probably a good thing she's leaving. Wouldn't want to REALLY hurt her feelings if someone was actually mean to her.
    Jul 2001
    ....i would never visit this site again....logging out
    Hang on, I think they're only threatenting to never visit again.
    Have a good one,
    neomaine
  8. Originally Posted by Bharathnat View Post
    Use DgIndex to build an index file then an AviSynth script with Mpeg2Source() including the deblocking option.
    Mpeg2Source("filename.d2v", CPU=2)
    CPU=2 deblocks only the luma, 4 deblocks luma and chroma, 6 deblocks and derings both luma and chroma. Then open that script with HandBrake (or any encoder that accepts AviSynth scripts) and encode. Example images:
    https://forum.videohelp.com/threads/337748-How-to-encode-xvid-with-h-263?p=2101241&view...=1#post2101241
    And if you're learning to use AviSynth it has other deblocking filters, Deblock(), Deblock_qed(), etc. with more control over the deblocking strength.
    Of course, what you're doing is replacing blocks with smooth gradients. That may or may not look better to you.
