TIPS ON HOW TO CREATE A GOOD MENU SYSTEM FOR VCD OR SVCD
Results 1 to 10 of 10
Best is TSCV...Just do anything with that.. I have also trid Ulead DVD Moviefactory and I would say it is very limited.
ulead may be limited, but the menus look nice and its very easy TVSC is complicated.
I've been using Nero for both VCD and SVCD. It takes a bit getting used to it, but you can do some pretty nice ones within Nero only.
Hope this helps. -
Nero authored menus are buggy and don't work on some players.
I strongly suggest you try VCDImager +/- a GUI (e.g., VCD Easy or TSCV). For authoring tips:
http://www.vcdimager.org/guides
Regards.Michael Tam
w: Morsels of Evidence -
can anything that is out right now make real chapters? <the ones you can skip forward on the remote>
vcdimager and its gui's like tscv can do that...But in (S)VCD's there is a difference in the way chapters work than in DVDs.
e.g. you play a movie from chap 2 and keep watching it till chap 4, now when you press next guess what you get.....chap 3 and not chap 5...
The VCD takes the chap from which it started to play as the reference chapter and not the one which you are watching presently. This is of course different to a DVD
This is not a problem with TSCV or vcdimager but the chapters for (S)VCDs are defined to work in this way...
Simple Menu Creation
By Nanorip in forum Authoring (DVD)Replies: 0Last Post: 23rd Nov 2010, 23:36 -
Menu creation in Encore CS5
By mobie29 in forum Authoring (Blu-ray)Replies: 0Last Post: 16th Aug 2010, 13:17 -
Menu Creation in DVDAuthorGui
By larrytxeast in forum Authoring (DVD)Replies: 3Last Post: 23rd Jul 2010, 11:52 -
DVD menu creation
By andrewgerm in forum Authoring (DVD)Replies: 4Last Post: 28th Aug 2008, 15:24 -
Newbie menu creation question
By dinkob in forum Newbie / General discussionsReplies: 1Last Post: 3rd Sep 2007, 12:49
