I got some clips that have pillarboxes that varyies in size over time .
Now i got some applications that I normally use to crop those out but they DO contant cropping.
So...
Is there some wonderprogram out there that could like ... scan thru the video and apply cropping according to the current blackbar size on each frame or something like that?
No, and after doing the crops you'd be left with a bunch of different resolution videos while they'd have to all be the same. So even if there was a magical program to do an 'adaptive' crop, it would also have to resize it properly, and if it was to keep the aspect ratio it would also have to crop from the top and bottom.
You'll have to do it all manually, perhaps using a bunch of trims, crops, and resizes in an AviSynth script. Or do a single and less than ideal crop and resize.
Letter being covered up by the letter next to it
By Cyan in forum SubtitleReplies: 4Last Post: 2nd Jan 2012, 07:05 -
Need help converting 4x3 dvd to 4x3 h264 mp4 for psp 1001 -add pillar bars?
By yoda313 in forum Video ConversionReplies: 0Last Post: 28th Feb 2011, 16:47 -
[SOLVED] Is there a way to crop pillar boxes within FAVC before resizing?
By usually_quiet in forum Video ConversionReplies: 3Last Post: 3rd Apr 2010, 17:37 -
using graphics in Pillar bars with 4:3 video in a 16:9 project
By eyarea51 in forum EditingReplies: 3Last Post: 21st Nov 2009, 22:28 -
How do I get rid of letterboxes and pillar boxes
By Tyrod in forum Newbie / General discussionsReplies: 3Last Post: 6th Feb 2009, 14:30
