Hi,
I have a question:
I want to know how to make a single 1080P video file that contains a DTS-HD soundtrack ?
The software I have:
The source is 1080P H264 MOV from a Canon EOS5D mark 2.
I also have the DTS-HD Master Audio Suite™ so encoding a DTS-HD file is not the problem, but I got Final Cut Pro 7
and this video editting program doesn't support DTS-HD...
I don't want to buy another expensive software package like Sony Blu-Print 6,
Is there another way to make a videofile (or container file) that can hold 1080P (H264) Mov file combined with
a DTS-HD soundtrack?
The best quality is for me very important, who can help me with the best work-flow based on the above software programs?
Thanks in advance.
Zerrax
Strange workflow.
First is the sound somehow sync'd to video? or separate sound (e.g. ADR/Foley/music)?
Normally you would edit multi-track audio, then encode DTS at the end.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Yes, the video is sync'd to audio (and everything is already editted)
(FCP can handle WAV files
These WAV files are encoded to DTS-HD in the DTS-HD Master Audio Suite™
So I got two files: a video file and a DTS-HD file.
My question is how to bring these two together in one container or other file format ?
I don't want to follow the normal Blu-ray authoring way, I'm just looking for a way to make a high quality single file format
can MKV handle DTS-HD? -
yes it can
so mkvtoolnix (.mkv) or tsmuxer (.m2ts)
transport stream overhead is larger ~4-6% -
Thanks!
This sounds like a very good solution for me!
Thank you all
Regards, Zerrax
How to combine *.264 video + *.aac audio to one file?
By video-fan in forum Video ConversionReplies: 5Last Post: 18th Oct 2011, 02:38 -
How can I reduce a 1080p video file to 720p and keep dts audio?
By jeff552004 in forum Newbie / General discussionsReplies: 6Last Post: 16th Oct 2011, 01:24 -
Can't get a 1080p DTS .mkv to play on PS3?
By leamingtonspaceman in forum Video ConversionReplies: 6Last Post: 27th Feb 2011, 08:40 -
How do i combine a video file and audio for two different movie sources??
By Kyisha in forum Newbie / General discussionsReplies: 3Last Post: 22nd Mar 2010, 06:03 -
Convert 1080p to 720p with DTS conversion to AC3
By El Duderino in forum Newbie / General discussionsReplies: 2Last Post: 23rd Feb 2010, 08:32
