I have a huge collection of Video files with varying sizes from a few MBs to a few GBs.
I want to take DVD backup of the video files in their appropriate Folder, Format, without re-encoding and with associated descriptive text files.
The Nero like Backup is of no use since the identity of each file is lost on storage media (DVD).
How do I go about it?
Note - I understand a software Video Charge Studio (http://www.videocharge.com/Products/vcs/features_list.php ) allows this. But, the software is not FREE and I have no commercial use of any tool or software. It is exclusively personal.
Thanks.
Results 1 to 15 of 15
Moving you to our general forum as this is not really any dvd ripping.
Wouldn't a cheap backup hdd be better?
edit: Didn't read the thread...Last edited by Baldrick; 2nd Nov 2011 at 04:03.
I have no idea what you mean by this but:
1) Just use ImgBurn to create a DATA DVD.
2) If you need software to calculate the best way to fit many gigabytes of data to several DVDs...
http://hcidesign.com/dvdspan/ -
@Baldrick
Thanks.
Yes, HDD is a good idea but DVDs are cheaper, better, more secure and safer storage media. No?
@hech54
Thanks.
The tool is a shareware. What I need is a tool that is FREE and that can split large video files (more than 4.3 GB) in size while retaining the tree structure. -
@hech
Thanks for the tip.
The DVD Span is working! The Trial limitation is for backup up to 7 DVD [max.].
I have a supplementary Question - Does InfraRecorder verify data burnt on the DVD-R? I don't see it in the Settings. If not, then the data integrity will not be reliable.
Thank you. -
Sorry, but I didn't get solution to splitting a large MKV file [6.6 GB] without re-encoding.
Any suggestions, please?
Thanks -
You can use mkvmergegui, add mkv, under the Global tab choose Enable splitting... and choose a size. Start muxing.
Thanks, Baldrick
Thanks to http://forum.videohelp.com
I am so glad I found this web site. The solutions are offered so fast and in easy-to-follow language that even a technical moron like me can perform"miracles"!Last edited by ConverterCrazy; 4th Nov 2011 at 07:42.
Split/Trim/Join MOV files (works great with Canon SX130's files)
By truchopol in forum EditingReplies: 3Last Post: 27th Jul 2012, 10:35 -
Program to split .mov files without re-encoding
By Guest in forum EditingReplies: 5Last Post: 21st Jul 2010, 20:09 -
Split FLV without re-encoding it?
By hzgg2 in forum EditingReplies: 0Last Post: 26th Sep 2008, 20:46 -
Cucusoft DVD to iPOD - Join/Split Files
By technologistau in forum DVD RippingReplies: 1Last Post: 16th Sep 2007, 04:49 -
Total Video Converter split my DVD into 9 single files
By topek in forum DVD RippingReplies: 2Last Post: 9th Sep 2007, 10:42
