  1. Hello people, I need to know how to find the bitrate of an mkv video.
    I used mediainfo, but i didnt get anything.
    The reason when I need this is cause when im converting the video I wonna get similar bitrate so i dont lose any quality or dont take up extra space
    Oct 2005
    666th portal
    try mediainfo in text mode. it give more info.
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Why do you want to convert mkv container video?
    http://www.kiva.org/about
    Dec 2005
    Pocatello, ID
    Why would you be converting it? If you're just trying to get it into a compatible container like .mp4 or .avi then it would be much, much, much quicker to just remux it.
  5. For sony vegas and after effects
    I got the text thing.
    How do remux it into .avi?
    I had problems before where it lag and stutter using .mp4 (done with mp4box) in after effects.
  6. Member edDV's Avatar
    Mar 2004
    Post the mediainfo text so we can see what is in the container. MKV and AVI are just containers. We need to know the video and audio codec details.
    View as text.
  7. eneral
    Unique ID : 181211778498546506434615093813540566185 (0x88541E79F81B44D1BDFB88FD856834A9)
    Complete name : C:\Users\AMD1090T\Desktop\Anime\Guilty Crown\[CoalGuys]_Guilty_Crown_-_01_[E1695770].mkv
    Format : Matroska
    Format version : Version 2
    File size : 431 MiB
    Duration : 23mn 0s
    Overall bit rate : 2 619 Kbps
    Movie name : Guilty Crown - 01
    Encoded date : UTC 2011-10-13 23:47:23
    Writing application : mkvmerge v4.0.0 ('The Stars were mine') built on Jun 6 2010 16:18:42
    Writing library : libebml v1.0.0 + libmatroska v1.0.0
    Attachment : Yes / Yes
    Video
    Format : AVC
    Format profile : High@L5.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 16 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 23mn 0s
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Title : H.264 720p
    Writing library : x264 core 118 r2085+614 d1cc25d
    Encoding settings : cabac=1 / ref=16 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / fade_compensate=0.30 / psy_rd=0.40:0.10 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=5 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:0.60
    Language : English
    Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : A_AAC
    Duration : 23mn 0s
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Title : 2.0 AAC
    Language : Japanese
    Text
    Format : ASS
    Codec ID : S_TEXT/ASS
    Codec ID/Info : Advanced Sub Station Alpha
    Compression mode : Lossless
    Title : Styled Subtitles (.ass)
    Language : English
    Menu
    00:00:00.000 : en:Part A
    00:04:01.616 : en:Part B
    00:10:32.465 : en:Part C
    00:21:23.574 : en:Ending
  8. Member edDV's Avatar
    Mar 2004
    OK that shows in summary
    Anime source
    1280x720p @ 23.976 film rate
    h.264 video codec
    AAC audio codec
    2,619 Kbps bit rate
    To make this open in Vegas, change container from mkv to .mp4.
    There should be no reason to recode video or audio, just change container.
    Set Vegas to 1280x720 23.976 project. To do any serious editing in Vegas or AE, you will need to decode h.264 to uncompressed or a digital intermediate.
