  1. Hi,
    I'm converting from an .mov to an .mp4 and every time I try my clip gets shortened. The video is still there in good quality, however, all the black before and after the video has been taken out. Please help.
    I've used:
    Any Video Converter
    4Videosoft AVC Converter for Mac
    Miro Video Converter
    WinXD Video Converter
    Try "remux" with avidemux, open mov, under video and choose copy, under format choose mp4, save. No video quality loss.
    If it wont help then post the details from the mov. Use MediaInfo.
  3. thank you for the reply. it did the same thing again. below is the result of the mediainfo. I've realized that the conversion replaces the black space with the first image of the video (about 13 seconds of black), the actual length isn't shorter. below the .mov are the results of the media info for the converted file through avidemux
    .MOV
    Format :MPEG-4
    Format profile :QuickTime
    Codec ID :qt
    File size :8.59 GiB
    Duration :6mn 2s
    Overall bit rate mode :Variable
    Overall bit rate :204 Mbps
    Encoded date :UTC 2011-10-30 13:49:01
    Tagged date :UTC 2011-10-30 14:52:46
    Writing library :Apple QuickTime
    ©TIM :00;00;00;00
    ©TSC :2997
    ©TSZ :100
    Video ID :1
    Format :AVC
    Format/Info :Advanced Video Codec
    Format profile :Main@L5.1
    Format settings, CABAC :No
    Format settings, ReFrames :2 frames
    Format settings, GOP :N=1
    Codec ID :avc1
    Codec ID/Info :Advanced Video Coding
    Duration :6mn 2s
    Bit rate mode :Variable
    Bit rate :202 Mbps
    Width :1 920 pixels
    Height :1 080 pixels
    Display aspect ratio :16:9
    Frame rate mode :Variable
    Frame rate :28.819 fps
    Minimum frame rate :0.072 fps
    Maximum frame rate :29.970 fps
    Color space :YUV
    Chroma subsampling :4:2:0
    Bit depth :8 bits
    Scan type :Progressive
    Bits/(Pixel*Frame) :3.384
    Stream size :8.53 GiB (99%)
    Language :English
    Color primaries :BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
    Transfer characteristics :BT.709-5, BT.1361
    Matrix coefficients :BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
    avidemux conversion
    Format :MPEG-4
    Format profile :Base Media
    Codec ID :isom
    File size :8.53 GiB
    Duration :6mn 2s
    Overall bit rate :202 Mbps
    Movie name :avidemuxtrial
    Writing application :Lavf52.78.3
    VideoID :1
    Format :AVC
    Codec ID :avc1
    Duration :6mn 2s
    Bit rate :202 Mbps
    Width :1 920 pixels
    Frame rate mode :Constant
    Color space :YUV
    Bit depth :8 bits
    Stream size :8.53 GiB (100%)
